Thread: VAG COM
    Jan 12 2015
    Kittanning PA
    VAG COM
    I tried to enable the hidden menu (2008 C6) and set the code as described more than several times in this and other forums. When I try to access it I get a message that's says No other menus are available. Maybe I'm doing it wrong. Anybody have this problem?
    the hidden menu in MMI 2G can be enabled with:
    [07 - Control Head]
    [Adaptation - 10] -> Channel 8
    change 0 to 1
    when pressing CAR and SETUP you get in the hidden menu
    Jan 12 2015
    Kittanning PA
    Bump ANYBODY? over 100 view and not 1 comment.
    Feb 06 2013
    CA
    Quote Originally Posted by 121rjb View Post
    [07 - Control Head]
    change 0 to 1
    Those are the instructions I followed when I did mine and it worked with no issue. Are you 'saving' it once you make the change? Take a screen grab of what you see via your vag-com and post it.
    Jan 12 2015
    Kittanning PA
    Quote Originally Posted by sun_dance View Post
    Thanks for the info
    I finally got it working, not really sure what the issue was but it all good now.
    Jan 24 2012
    Calgary, Alberta, Canada
    Sometimes you need to press car, then hold setup. If you press both at the same time sometimes it doesnt register.
