So I've had my B6 for a few months now. Round 1 of this overhaul consisted of timing belts and components, thermostat, coolant hoses, high pressure p/s line, p/s pump, water sensors, Febi B5 S4 motor mounts, and many other things.
This round, and I hope is the final, will include the following
1. Subframe replacement (current has a busted bushing)
2. 034 control arms
3. 034 rear transmission mount
4. 034 breather hose kit
5. 034 Billet DV
6. Block to Oil Cooler Adapter Gasket
7. Oil pan gasket
8. Steering Rack (by Rack Doctor)
9. Intake manifold gasket (plan to remove for breather hose replacement)
10. Oil level Sender Seal
Is there anything else I should add onto this list while I'm working in these areas?
