Results 1 to 7 of 7
Thread: Indicators
    Aug 01 2012
    Houston, TX
    Indicators
    Sorry if this has been answered a thousand times...
    Can anyone tell me what these indicators mean? I can't find a list of Information Display indicators anywhere so far... only dashboard indicators.
    Established Member Three Rings mpsmith's Avatar
    Aug 08 2014
    Audi S4 Audi A6 Audi S4
    United States
    Should be in your manual lol
    Senior Member Three Rings blocke's Avatar
    Jul 26 2013
    1990 BMW 325i (sold), 2006 VW GTI (sold), 2006 A4 S-line (sold), 2014 Jetta SportWagen TDI
    Temecula, CA
    First one is "dipped headlight". Could indicate a problem with your AFS system, high beam, ballast, etc. a VCDS scan will tell you.
    The second is TPMS error. One or more tires is reporting pressure below the threshold value stored in your settings.
    Performance: Fast Intentions 12" resonated cat back, ECS Snub Mount, JHM LTW Crank Pulley, JHM IM spacers, Optima Red Top, Dimple Oil drain magnet, 034 engine mounts,
    Suspension/Brakes: JHM LTW rotors front & Rear, Hawk HPS Pads, VMR V708's, H&R Sport springs, 034 strut mounts.
    Visual: Lamin-X on headlights, 20% tint , ZIZA city LEDs, Ziza License place LEDS, Interior LED conversion, R8 oil cap, 996 coolant cap
    Instagram: lockebrian
    Aug 01 2012
    Houston, TX
    Totally right, Missed it in the manual. Actually I couldn't find the dipped headlight indicator but the tire one is there.
    If the tire pressure is too low, it will show the flat tire without a line. The flat tire with a line means Malfunction. Probably because a tire sensor went out.
    Is there a way to figure out which tire sensor it is? Also, does the spare tire have a sensor?
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    The full sized spare should be equipped like the rest if it's OEM. You will have to let the car know your mounting a new wheeel on though via procedure in the manual.
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
    Senior Member Two Rings nr103's Avatar
    Oct 15 2013
    CO
    Most tire shops can test your TPMS sensors to determine which one(s) is faulty. I went the other route and just disabled the TPMS altogether and monitor pressure manually regularly.
    '07 S4|Gutted Downpipes|JHM 91 Octane Tune
    Aug 01 2012
    Houston, TX
    Since my car is 2005.5 S4, I just went ahead and bought 4 new sensors and valve kits from ECS and had the tire shop replace them. No sensor for the spare tire, since the manual says the car should read 4 tires only.
    No TPMS error for a few days then it comes back on... Do I need to activate them somehow? Vagcom?
