Results 1 to 2 of 2
    Sep 05 2012
    light replacement needs coding?
    Had an error "Audi Adaptive Light Defective" come up and the dealer traced it back to a defective cornering light bulb- replaced under warranty. So that's fixed. But the service note also said "SVM required coding of 5 modules... coded successfully. "
    Now I'm noticing that some VCDS settings are gone, even things that have nothing to do with lights. So far I've noticed TPMS is not working (it doesn't come with my Canadian car but I had it enabled with VCDS), the windows/moonroof control on long keypress and hidden menu access is gone. Interestingly, they seem to have left the gear # display in D and S mode.
    My question is whether this is normal to expect for a bulb replacement or if the tech just got carried away? I might bring it up on the satisfaction survey. I've been thinking of buying a VCDS cable anyway as the person who did the original customizations for me has moved away.
    And when my warranty is up, do I really need to recode something when a bulb burns out?
    2013 S4 Premium Package (Canada; like US Prestige) / Phantom Black Pearl ext / Nappa Black&Magma int / B&O, Nav, S-tronic DSG, Sport Diff, Michelin Pilot Sport 4 S wrapped around scuffed up 19" potato peelers / 3M See-through brassiere // GIAC/AWE Stage 2 + TCU tune - CTSTurbo Intake // Winter mode: 18" Nokian Hakkapaleno? R2 on RTX Ingolstadt gunmetal wheels (B7 RS4 knockoffs)
    May 16 2010
    houston tx
    i have had service and lost some coding as well. I think it depends on what the service department load or reloads software and this is where you will lose some stuff. they probably didnt even know they changed any setting you had.
    2012 Audi S4 DSG, Roc Euro Intake, GIAC stage2, GIAC DSG tune
