Results 1 to 4 of 4
    Active Member Two Rings netispguy's Avatar
    Sep 28 2014
    2016 RS7; 2015 SQ5 all options
    Los Gatos, CA
    Clear bra or race tape (or both)?
    I am thinking about taking a new RS7 to track day at Laguna Seca. I have been advised to ether clear bra or race tape the front to keep it from getting damaged by random debris. This would be in addition the to normal taping of the front and rear lights, etc.
    Any advise would be helpful.
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Clear bra is long-term protection. If you want to protect the car against road debris period, get the clear bra. I would certainly recommend it if you're planning on tracking the car on a regular basis. Otherwise, if you're not worried about long-term protection and simply wish to protect the car against minor debris while at the track, you could go as simple as painter's tape. Clear bra is definitely the better overall solution as it will give you a little more protection against bigger debris than simply taping would.
    l Previous: 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l 2025 Rivian R1S Tri l Midnight/Dark Mountain l XPEL Stealth Wrap l
    Registered User Two Rings XPEL's Avatar
    Jan 21 2013
    San Antonio, Texas
    Tracwrap
    Quote Originally Posted by netispguy View Post
    netispguy,
    Paint protection is great for all occasions, but is especially important for track days. We have a product called Tracwrap by XPEL. This 8.5 mil thick film (compare to painters tape at 2-4mils thick) is very durable and is still easy to install. The video below will demonstrate it's durability against blue painters tape.
    Hope this info helps, good luck on the track!
    Veteran Member Four Rings kiku's Avatar
    Jul 11 2013
    2001 Audi S4
    Pittsburgh, PA
    I hope you have a spare set of tires and new brake rotors on standby :)
    From my RS7 track weekend (on stock tune!)
    2008 997.1 GT3
    2015 Allroad
    2014 Ram 3500 Dually (the double wide)
    2014 Phantom Black RS7 w/ APR Stage 1 Tune (sold - farewall fast rs)
    2001 B5 S4 (the track slut)
    2013 Q7 S-Line (sold)
