Hey everyone, im new to the forum but have searched through it to see if i could find an answer to my problem. So far it seams like a maf or cat problem but i unplugged the maf and it idles the same and still hits the "rev limit" only difference is it will only boost to 5psi at wot. It cant be a clogged cat because it doesn't have a cat so im not sure what it could be. Pulled dtcs and had a code for the cat and a p1136 (long term fuel trim add. fuel b1 system to lean) so i researched that, bad maf, o2 sensor or vac leak. Boost gauge says 20 vac at idle, 23 vac on decel and will hold 13 psi wot (t.a.p stage 1 ecu). No misfire codes or any other codes. Any idea what it could be? Any and all responses are appreciated!
