Results 1 to 14 of 14
    Sep 25 2014
    Birmingham, AL
    My B5 A4 breaks up at high acceleration
    Ok I have a 2001 a4 1.8t with a k04 turbo, 5 bar fuel regulator apr chipped computer, 3 inch maf, and a front mount intercooler... So since I got all this installed I have experienced what seems to be the plugs like breaking up at high rpms and what feels like miniature back fires.. I also get a back fire every shift when accelerating hard.. I have check vacuum check my plugs and my coils no issues like that. Also checked for an exhaust leak I don't have one.. Maf is good and injectors are good.. I had the TT injectors on there and it was worse so I put the stock back on there... Just trying to see if anyone has run into anything like this before???
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Yes, change the plugs and decrease the gap of them. I had the same issue.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Apr 01 2011
    B5 on jack stands
    charlotte
    does your tune call for a 3" maf?
    Sep 25 2014
    Birmingham, AL
    I did that still same issue..
    Sep 25 2014
    Birmingham, AL
    I called apr and it says that should be fine inside the parameters but I will switch it out and check and see
    Apr 01 2011
    B5 on jack stands
    charlotte
    check your crankcase ventilation/pcv area for cracks/rips in the plastics or rubber hoses.
    same thing for the inlet pipe
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    When did APR start making a 5 bar, 3inch maf, tt injector K04 tune?
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Sep 25 2014
    Birmingham, AL
    They don't but I have done my research and all this stuff stays inside the parameters of the tune .
    Apr 01 2011
    B5 on jack stands
    charlotte
    just a suggestion but I would put the stock maf housing back in, stock fpr back in, and the stock injectors back in. if the tune does not call for it wether or not it may work or not I doubt your gaining much or any advantage by using that setup.
    Veteran Member Four Rings RallyeBourne's Avatar
    Sep 10 2013
    San Diego County, CA
    'Within parameters' doesn't always mean 'ideal.' Without having the tune optimized for those components, you won't see a gain, and as you are experiencing, you could run into issues. Your tune thinks it's pushing 4bar of fuel for xx milliseconds. You're actually pushing 5 bar of fuel for xx milliseconds. Too much fuel in the system could be your backfire issue. You could also be flooding your plugs, causing those little misfires. Trust me, I WISH it was that easy to gain a few ponies. But it's not. So stahp.
    Sep 25 2014
    Birmingham, AL
    Alright well I have already put the stock injectors in with the 5 bar and that seemed to help a ton, but it still happens so I will put the stock regulator back in.. I noticed an issue with the inlet as well has anyone used this one from racewerks http://www.evolutionracewerks.com/node/64 if so is it worth it
    Oct 31 2014
    NH
    Quote Originally Posted by 01UA View Post
    What are your plugs gapped to?
    2014 Audi S4 - 6MT
    2000 Audi A4
    Sep 25 2014
    Birmingham, AL
    I have them gapped at .28 and I fixed the inlet tube and it is gone now.. I just can't believe that I just got that and it had a cut on the back side.. I also put the stock maf housing back on and I believe that did the trick..
    Dec 23 2009
    Boulder, CO
    A 3 inch maf is going to give the computer numbers low by 20% over stock, a 5 bar is going to give 25% extra fuel, tt injectors, even more so. On a narrowband, I'd doubt that it'd even run. That's a lot of compensation for the ecu to even handle.
    You're not going to outflow the stock MAF with a K04. Stick injectors, maybe
