Originally Posted by
drums4life2005
Expenses is not true if you know where to look for a transmission. First of all, I would sell my automatic transmission because it only has 73k miles on it. Then with that $$$ I will buy all the necessary parts INCLUDING transmission. I found a manual with 80k miles for $625. Yes, parts can be expensive, but that is if you don't know where to look. Also, I have some friends that own a car shop, and they have a lift, so the swapping is not a big deal. Throw in a couple hundred for labor and there won't be any sweating work for me.
Lol yeah ok.
Let me put it this way.
Tranny is $600 on the cheap end. Clutch is $700ish, I am assuming you are replacing it and not reusing an old clutch that will need replacing in 30k. You need pedals which will cost 200-300, you need the trim around the shifter, you need the shifter, you need axles, let's say $600 on the cheap end for all that. Now you also need a manual wiring harness, $150 if you get lucky, ok, now you need to pull the engine and tranny, remove all the old wiring, install the new wiring recode the Ecu, take apart the trans tunnel and put your shifter in place, align it, flash the Ecu so it knows it is manual now, alright, now you need fluid for the tranny which is 50-70, and coolant to refill the engine that you just pulled, so now another $20 for coolant.
Easily $2500 right there.
Ok now labor, you said you don't want to pt any sweat equity in so consider the average shop charges $700 for r&r for clutch replacement, but this also involves pull the engine, rewiring installing pedals and shifter, a regular shop is going to want 1700-2000, but you think you're friends will do it for $100 a piece?
A manual swap just doesn't even make sense, just sell the car and buy a manual, it will be cleaner that way, cheaper, and less trouble.
But hey if you don't believe me go ahead and jump into it and come let me know in 6 months how it was too tough, or hit some electrical gremlins that you can work around.
