Results 1 to 7 of 7
    Sep 06 2013
    Review of awe exhaust, the transmission insert, and hr coilovers on my c7 a6 3.0t
    I got all three installed today. Instead of posting on the various threads, I'm doing a single post.
    The trans mount insert definitely makes a difference! The up shifts are smooth. Gone is the harshness, feels more precise. Downshifts same. You don't feel them anymore like I used to. Best 57 bucks I spent on this car.
    The awe exhaust. At first I though it was too loud. I have the catback without the down pipe. It gets pretty loud right at 2000-2500 rpm. That said, I'm getting old, it's not that bad. The sound is good. After driving home on my 1.5 hour journey it grew fast on me. I love it. It gets quieter as the rpms rise. When driving "normal" you can barely hear it. The most you hear it is in the low rpm range. There is zero drone. At cruising speed, you can't hear it unless you step on it. Now the best part. When you floor it, this thing sounds amazing. In between shifts there is this absolutely awesome crackle/burp. It's what made me fall in love with this exhaust.
    The He coilovers are great. I did the least amount of drop which basically closed the wheel gap. Ride quality is not sacrificed at all. Ride looks so much better, and handles great too.
    I'll post pics later.
    2013 A6. Prestige/Innovation/20" wheels/LEDs
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    Pictures kind sir!
    What tranny mount did you get?
    TortoiseA6
    Sep 06 2013
    The 034 motorsports insert.. it's raining here, I'll take some as soon as it stops.
    Sep 06 2013
    Veteran Member Four Rings 07S6's Avatar
    Sep 17 2010
    Looks great! Did you have difficulty aligning the tips? Maybe it's just the pic, but looks like left side is not centered.. I assume you can also opt to not use the AWE tips and add on your own quad tips for a quad set up?
    2012 A7 Prestige, Innovation Pkg, Sport Pkg, B&O / APR Stage2, AWE Touring, Injen intake
    2012 A6 Prestige - Phantom Black/Nougat/Innovation Pkg. (sold)
    2007 S6 5.2L V10 (sold)
    Sep 06 2013
    Thanks! They were aligned. But from use, as the metal settles they moved a bit. I'm going back in, in 2 weeks, to get new tires, control arm bushings, and alignment done, I'll have the tips/exhaust aligned again.
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    There isn't enough room on the A6 rear valence to support a quad tip setup. You would either have to try cutting the valence to widen it, or replace it with the S6 valence. Believe you can only do the latter without having to buy the entire S6 rear bumper and valence setup if you have the S-Line or Prestige package.
    Quote Originally Posted by 07S6 View Post
    l Previous: 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l 2025 Rivian R1S Tri l Midnight/Dark Mountain l XPEL Stealth Wrap l
