Results 1 to 6 of 6
    Sep 17 2005
    Fremont, California
    034Motorsport C5 Audi RS6 Tuning & Tip Chip Tiptronic Software Upgrades Now Available
    034Motorsport is thrilled to announce the availability of C5 Audi RS6 Tuning and the C5 Audi RS6 Tip Chip for 4.2L Biturbo powered Audi RS6 cars manufactured from 2003 -2004! Developed entirely in-house by 034Motorsport engineers, this line of performance engine and transmission software was built from the ground up to ensure performance without compromise.
    Through optimization of the factory ECU's boost, fueling, and timing maps, 034Motorsport C5 Audi RS6 Tuning safely yields huge increases in horsepower and torque from the twin-turbo V8 powerplant, resulting in a much broader powerband. 034Motorsport's proprietary changes to the ECU have also addressed other shortcomings of the factory calibrations by increasing the rev limit to 6,800 RPM, and enhancing part-throttle mapping for improved drivability.
    After extensive analysis of the factory Tiptronic TCU (Transmission Control Unit) mapping, 034Motorsport engineers were able to make calibration improvements which are part of the C5 Audi RS6 Tip Chip Transmission Software Upgrade. This performance transmission software increases shifting speed and optimizes shift points, while also raising the maximum shift point to 6,800 RPM in order to make use of the Stage 1 ECU Upgrade's broader powerband.
    C5 Audi RS6 Stage 1 Tuning Features:
    • Peak Horsepower & Torque: 515 Horsepower / 580 Foot-Pounds of Torque
    • Peak Horsepower & Torque Gains Under Curve: 133 Horsepower Increase at 4,250 RPM / 165 Foot-Pounds of Torque Increase at 4,250 RPM
    • Developed In-House on the Street, Track, and 034Motorsport's Chassis Dyno
    • Optimized Boost, Timing & Fueling Maps for Increased Horsepower & Torque with 91 Octane Fuel
    • Peak Boost Increased to 17.5 PSI
    • 93 Octane & 100 Octane Tunes Available Upon Request
    • Increased Rev Limiter to 6,800 RPM (034Motorsport C5 Audi RS6 Tiptronic TCU "Tip Chip" Upgrade Recommended)
    • Speed Limiter (Governor) Removed
    • Improved Throttle Response & Power Delivery
    • Refined Throttle Mapping for Part Throttle Drivability
    • Increased Fuel Economy
    C5 Audi RS6 "Tip Chip" Tuning Features:
    • Developed In-House by 034Motorsport
    • Raised TCU Rev Limiter to 6,800 RPM
    • Increased Shift Speed
    • Optimized Shift Points
    Application Guide:
    • 2003 - 2004 Audi RS6 4.2T (C5)
    Available Tunes:
    Installation:
    • Option 1: Flashed directly through your vehicle's existing OBD-II Diagnostic Port by 034Motorsport.
    • Option 2: Flashed directly through your vehicle's existing OBD-II Diagnostic Port by you, using the PL34 Handheld Flash-Loader. You will receive a free second map with purchase of a PL34 Handheld Flash-Loader! (Sold Separately)
    Wheel Horsepower Dyno Plot | 91 Octane | Stage 1 Tune for C5 Audi RS6 4.2T
    Feb 20 2012
    Portland, Oregon
    I have the mtm tcu chip. Is there any difference with your tcu chip compared to the mtm one.
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by mbagge01 View Post
    I honestly don't know much about the MTM TCU Chip, but ours is designed to complement our Stage 1 ECU Upgrade. It raises the TCU rev limiter to 6,800 RPM to give you a broader usable powerband, makes gear changes quicker, and has optimized shift points.
    If you already have a TCU chip, I'd highly recommend giving our Stage 1 ECU upgrade a try.
    Oct 29 2005
    10speed
    San Francisco, CA
    dat torque curve
    - Clint
    Sep 17 2005
    Fremont, California
    dat torque curve
    All of the torques!
    Sep 17 2005
    Fremont, California
    Bump! Thank you for all of the interest.
