Easiest way to check if yours is bad is to remove this:
Click this bar to view the full image.
http://i366.photobucket.com/albums/o...9-16085412.jpg
Once that is removed, try blowing into the flexible pipe. You should not be able to blow through this. If you can, you have to make a choice of three options.
1. Replace with OEM part # 06F129101P for roughly $75, risking the same thing happening again in the future.
2. Cheap and easy "PCV Fix" of which I will discuss the downside.
3. Look at your catch can options.
The PCV Fix
The PCV Fix is a quick, easy, cheaper way of fixing your broken PCV. Sounds great, right? Nope. This should only be temporary. Reason being, it is sealing the issues caused by a broken PCV, but also allowing everything that should be filtered out back into the engine to turn into sludge. Sure, use this as a cheap fix while you save for a catch can, but don't keep it forever.
The Catch Can
Catch cans consist of metal construction that won't break with age. They catch harmful moisture and groooooss oil deposits instead of returning it into the engine to be burnt into carbon deposits. It also seals any places left for our precious boost to escape.
There are two main types of Catch Cans. The closed-system, and the vent-to-air system. Both have their benefits, but only one is street legal.
Vent-to-air systems do just that. Vent all the nasties straight into the air. Mostly used in racing applications. It is bad for the environment, and can really make a mess. This is probably the best system for your car, but not really the one you should go with.
The closed-system instead of letting all the grossness out, uses a series of screens/baffles/filters to force oil and moisture to the bottom of the catch can where you can empty it out into a cleaner/safer depository. This is the most likely system for our cars.
There are many, many options for a catch can setup for our cars. You can even do custom setups from many ebay type options. There are also many full kits comprised of everything you need, which are the options I will lay out before you, in no specific order.
BSH is probably one of the more widely known companies for catch cans for our system. They have products ranging from just a block off plate that you can use with any catch can system, to stage 2 and even a racing staged version. Stage 2 is the most viable solution at this point.
Sorry, stole this from another thread...
