Originally Posted by
ADCS
1) With the wheels off the ground is there any way to lock the front axles so that I can remove the tripple-square bolts for the front axles? I tried stomping on the brakes but this only worked for the driver side. The passenger side would still spin. There is no brake fluid in the car so there likely isn't enough clamping force. I am not sure why it held up for the driver side and not for the passenger side. I tried putting the trans into gear but the axles would still rotate. Is this normal?
Screw in the lug bolts. Use a pry-bar between them. Removing the inner triple square bolts like that is easy. Using the same counter-hold method to remove the outer axle bolt (large) is more difficult, because it's in there at a much higher torque.
You can wrap some sand-paper around the drive-shaft, and grip it hard with one hand while you loosen the bolts. That way you have a better grip. It also helps to heat the bolts with a torch, then spray the bolt head with cold water. That way, the bolt that expanded and widened the thread-hole its in, shrinks from the water, and loosens up. You have to break it loose shortly after the water.
