Results 1 to 12 of 12
    Jan 18 2015
    Austin TX
    Stage 2 b5 s4 diverter valve question
    I have a stage 2 b5 with a stock diverter valve and I was wondering if this will cause a boost leak and what diverter valve would you recommend?
    Established Member Two Rings rhammyS4's Avatar
    May 20 2011
    2013 Stage 2 S4, 2017 Subaru WRX FBO, 2021 VW Tiguan
    Yes, bad diverter valves could cause boost leaks. Pick up some 710N's.
    Current: 2013 Ice Silver Silver S4 / EPL Stage 2 / CTS Pulley / CTS Intake / Niche Essen M147 / ST Coilovers / JHM HFC / AWE Touring
    Gone But Not Forgotten: 2002 Rare Silver S4 / EPL Stage 2 / ST / Podi / Vibrant Catback / SSAC DPs / K&N / 710N / 3SDM
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    710n's or some apr r1's, with the bi pipe. good mod cuz you eliminate the tbb as possibly failing later
    2008 Ibis RS4....GETing tuned
    Established Member Two Rings DarthWinja's Avatar
    Jul 09 2012
    Denver
    I'm not a fan of the R1s. Had one before on my A4 and it honks (like a goose) going in/out of vacuum sometimes. It works great but be warned of the honk.
    Rose: 00 S4 6MT. 034 MS diverters, piggies, stage 1 ecu, Apikol diff brace, Stern rear diff bushings, E-codes, AWE vent mount boost guage, H&R premium street coilovers, Fast Intentions stage II cat back exhaust, short shifter, drive train stabilizer, Doge sticker. wow.
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    I'm running the SSAC diverters with the medium springs. Seem to work well.
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Quote Originally Posted by jpurre View Post
    I was wondering if anyone was running those. How long have you had them installed and at what boost levels? You are running the 3F tune right?
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Quote Originally Posted by Zba View Post
    I've had them for 15k miles on my F21 setup. Yeah 3F tune ~20psi. Work like a charm so far. I've been meaning to clean them and maybe try different springs to see if there was any benefit. Only drawback I've seen is the chrome is peeling, but no mechanical issues.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Been rocking the same 710n dvs for 6 years
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Quote Originally Posted by CELison View Post
    For those who say the 710n's aren't up the job, CELison has one of the healthiest stage 3 cars around.
    Nov 05 2009
    Denver
    I currently have 710ns as well but I like the bling factor
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    Quote Originally Posted by axnjaksn View Post
    I'll second that---The BI-PIPE is a very good add-on also the 710N's work VERY well...I was using the Forge 007 valves but got tired of removing them to re-lube the o-rings every 4000 miles...
    PS- they're a BUNCH cheaper than ANY of the aftermarket valves...I've had them on the vehicle for nearly a decade-NO issues!
    Jun 11 2013
    2004 BMW 325i
    South Florida
