Results 1 to 19 of 19
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    acceptable oil pressure range?
    I know most of us don't monitor oil pressure (or even have a gauge) but i figured it was worth a hail mary... does anyone know what acceptable oil pressure is at idle, or what is acceptable oil pressure range?
    Thanks
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    Idle oil pressure spec is 2 bar or 29 psi. Ask me how I know...
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    how do you know
    Nov 11 2013
    Charlotte NC
    Dealer blew up my engine after running it with no oil pressure...
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    how much is no oil pressure
    Nov 11 2013
    Charlotte NC
    Like zero. Started out at 1 bar when they first cranked it and tapered off to 0 as my oil pump locked up and they kept running it. Destroyed my turbo, bearings, crankshaft. Pretty much everything.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    damn.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    did your oem pressure light not go off?
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Nice, I wish they would blow up my engine. Id love to get a zero miles crate engine directly from the Fatherland.
    Nov 11 2013
    Charlotte NC
    Yeah it did thats why i took it in the first place. I had it towed cause the oil pump was failing. And they refuse to pay for it.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    damn that's crazy. did they install a brand new motor for you?
    Veteran Member Three Rings swaggerwagon's Avatar
    Sep 28 2012
    NC
    Quote Originally Posted by audihere06 View Post
    audi of charlotte?
    B8.5 3.0T/ B5.5 1.8T
    Nov 11 2013
    Charlotte NC
    Audi Northlake
    Nov 11 2013
    Charlotte NC
    Quote Originally Posted by drumnjuny View Post
    No im having to purchase a used motor and have it installed by Eurowise. I would do it myself but they are gonna replace all seals and gaskets, plugs, belts, chains, water pump, tensioners and everything for $1500-2000 installed + price of the engine.
    Sep 28 2012
    NC
    Sucks to hear that. Mike runs a good shop. Does any work I can't/won't
    Nov 11 2013
    Charlotte NC
    I guess i should tell the whole story. So my oil pressure came on in red (oh shit kill it now). So i cut it off and coasted up the off ramp, had the car towed to my house where i read the codes and displayed a P000A (low oil pressure) and a P0333 (knock sensor 3). I also pulled the cover off the timing belt to make sure it hadnt jumped or snapped, and pulled some oil out with a vacuum pump(not much just an oz or 2). Decided the next step was to pull the oil pan. Would have done it myself but I dont have a lift or anything like that so i just had it towed to audi northlake. I left two signs on the car saying "DO NOT START" i also wrote the codes and "oil pump failure". I went over there the next day and they hadnt started on the car yet. I told them do not work on the car until they call me to discuss what I want done. Never got a call. Had to go back over there the next day to find out they started it and ran it up to operating temp as told to me by the tech who did it. In this they discovered my oil pressure to be at 1 bar instead of 2 and then the oil pressure just dropped off completely. (All this was done without my permission). Then they decide to pull the pan and its fucked. The pictures are in my thread ill link. Now the issue is they say the damage was done before they got it and its not their problem.
    Nov 11 2013
    Charlotte NC
    Quote Originally Posted by swaggerwagon View Post
    You in the area? Theres not many people around here on az.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    wow. you need to call AoA and have them fix that fuckup immediately. don't stop until they pay for it. that is absolutely ridiculous.
    Sep 28 2012
    NC
    I was, I live in Fay now.
