Results 1 to 13 of 13
    Registered User Four Rings
    Aug 24 2010
    North Carolina
    BFI - B5/B6/B7 Engine & Snub Mounts
    After a lengthy period of design and testing we are proud to announce the release of our complete replacement engine mount for Audi B5, B6, and B7 vehicles. We are the first to develop a fully Billet Replacement mount for the Audi/VW Longitudinal platform that retains all of the factory alignment and stress relieving features. The use of billet aluminum instead of cast and an increase in minimum thickness creates a mount that is dramatically stronger than the cast stock mount.
    This mount will completely replace your old, tired, hydraulic engine mount. In its factory form, the engine mount is fluid filled by Volkswagen/Audi to aid in creating a softer, cushier ride. This softness is a detriment to performance and overall longevity as the fluid within the mount can often cause premature failure. We eliminate this possibility by replacing the mount completely with our proprietary bushing and bracket/Cup design. Maximizing bushing area while trying to minimize vibration where possible gives our mount the advantage of having the best ride characteristics possible from a urethane bushing mount.
    The B5/B6/B7 engine mounts are available in two stages -
    • STAGE 1 with its 65a durometer bushings are geared towards the spirited enthusiast who wants better control over motor movement without the sacrifice of excessive vibrations.
    • STAGE 2 with its 85a durometer bushings are more for the hardcore enthusiast who is more concerned with performance than cabin vibration - great for spirited runs and track cars. Not recommended for daily driven vehicles!
    Aug 24 2010
    North Carolina
    We are proud to announce our new BFI Performance Snub Mount! After a lengthy design, testing and production process, we are finally able to offer the best snub mount available to B6 / B7 Audi owners.
    The factory snub mount is a well known weak point of the engine isolation system in your B6 or B7 chassis Audi. Made of a soft foam rubber, the OE piece is great for initial comfort, but lacking in longevity and performance. The factory rubber snub mount is notorious for cracking failing causing those mysterious and annoying clunking sounds coming from your drivetrain.
    Our Performance Snub Mount is constructed of noticeably stiffer polyurethane (75a) vs. the factory rubber mount. Our parts are designed to stand up to the abuse of hard or even just spirited street driving. Reduce your engine movement and improve shifting with this economical upgrade!
    Veteran Member Four Rings brandonpham's Avatar
    Dec 06 2014
    Hm, best snub mount out there? Really now.
    Aug 24 2010
    North Carolina
    Quote Originally Posted by brandonpham View Post
    Yep.
    Veteran Member Three Rings DaveyDave424's Avatar
    Aug 02 2012
    LOS ANGELES
    i have a snub mount [ different brand ] but i can wiggle it around with my hand. are snub mounts supposed to be tight ?
    Established Member Two Rings bseven's Avatar
    Jun 26 2009
    '07 335i BT toy
    Cincinnati
    Why did you guys choose polyurethane for your bushings over rubber?
    Aug 24 2010
    North Carolina
    Aug 24 2010
    North Carolina
    Aug 24 2010
    North Carolina
    Throwback Thursday! Going through our old files and found our old PVW print ads. :)
    Aug 24 2010
    North Carolina
    @garrettleeharvey showing what 75k miles can do to OEM mounts in a MK5.
    Aug 24 2010
    North Carolina
    @josh_mk6gli with our Stage 1 engine mounts in his GLI.
    Aug 24 2010
    North Carolina
    Aug 24 2010
    North Carolina
    @r32.4275 got his Stage 2 mounts custom finished and they look awesome!
