Results 1 to 40 of 43
    Established Member Two Rings nagarob6s4's Avatar
    Mar 11 2015
    Newly installed jhm Parts / 2015 rt charger test.
    Hey all, I've had my nagaro b6 s4 going on two years. When i bought it it had lowering springs, fast intentions exhaust, aftermarket wheels, jhm short shifter kit, and a apikol snub. Only thing I did up until recently was put vmr 710s on it and 2.5" careless downpipes.
    I though the car was decently fast ran it with plenty of cars and it was no slouch. Well for 2014 Christmas I decided finally to purchase the jhm tune, lwcp/6 rib kit, LWFR, and 034 snub. All I can say is wow. This car is a beast compared to before. The torque difference is amazing, I find myself grinning every time I press the pedal.
    Well after I installed the parts. Is ent out for a test run, my neighbor apparently heard me. He follows me and flags me down and a abandoned road. He said it sounded nice. He asked if is wanted to test those New parts out. He has a 2015 charger rt with 370hp hemi.
    Only mods he has are catback and 9 gallons of race fuel. We line it up, I'm a nerd and didn't want to blow my clutch so I launched it at 3800. He was half a car behind my rear bumper through first and second. His front bumper stayed at my rear quarter panel through 3rd. He passed me when I was in fourth gear barely just barely. He got his headlight out in front of my front bumper before we shut it down.
    It kind of caught me off gaurd that he reeled me in. Anyone else have any input on those new hemis? What made me mad was he sad if he did launch control right he would've pulled me of the launch . Something about my car was fast for what it is .
    Nogaro B6 s4
    JHM 93 tune - JHM Intake manifold - JHM Intake spacers - JHM bypass delete - JHM LWCP/Rib kit - JHM LWFR - ECS LWRR - FI 2.5 catback - XS power DP - JHM shifter/JHM delrin - Evo MS intake/Heat shield wrapped - 034 MAF hose - Apikol snub - Tien Springs - Sparco (26lb) seats - VIS carbon Fiber Trunk - Alzor 010 (21lbs) - Dunlop sport maxx (20lbs) - Optima red top - spare tire tools removed - Aux radiator delete
    Mar 11 2015
    Here is a picture of my s4
    Nogaro B6 s4
    Jun 09 2014
    BMW E28 with S54 Swap, rack and pinion conversion, vacuum brake conversion
    Jacksonville,FL Lincolnton,GA
    Nice looking ride. Give that engine bay some love. Yea AWD can be great and it can suck. In this case it sucks.. power. Damn extra drive train loss. Oh thermodynamics, curse you! FYI its better to launch harder; you want a little wheel spin, if not your drive train is taking a lot more of the load and you can break things. There is a fine line between just the right amount of wheel slip and spinning your tires.
    Veteran Member Three Rings Brettannica's Avatar
    Oct 14 2012
    2010 Audi A4 Avant
    Perth, Western Australia
    All I can say is “Thank f*ck you weren’t racing a GSXR”
    In The Garage: B7 S4: JHM Tune Carbon Fibre: Vis Racing Hood, Relak Skirts & Paddle Extensions, Blades, DTM Deck Lip : 034 Snub & Bracket : JR Air Filter : H&R Springs : F.I. Catback : Gunmetal 19” 6RS V10’s • B8 A4 Avant: BSR Bling : 19” 4RS V10’s : V-Tech Chip
    Previous Rides: • E32 BMW 740i • E36 BMW 325i • B5 A3S • B6 A4 • Ford Falcon 351 • Triumph TR8 • Vauxall Super Tourer • Saab 9-3 • Saab 9-5 • Toyota Prado 4x4
    Senior Member Two Rings b6dolphins4's Avatar
    Aug 07 2011
    Binghamton,NY / Raleigh, NC
    Interesting, I would say given more roadway you should have pulled him. Not drastically but on the top end you should start to pull away from him a little. I can't imagine he's gaining that much power from just race fuel and a CB. I would try doing a few more runs with him, granted you can find a safe place to do. so https://youtu.be/mXdeQOjuvJk
    https://youtu.be/xJu588DPh3I
    I
    2004 DG S4
    Mods:| JHM 93 Tune |JHM Stg 4 Clutch | 034 Light Weight Flywheel | Trexturk Cat less Dp's | Custom 2.5" Non-res Magnaflow CB | K&N Drop-in | 034 MAF hose | Apikol Snub/ Zero Gap Bracket | 034 Trans mount | JHM S.S. | JHM Knob |
    Veteran Member Four Rings R&Cs4's Avatar
    Oct 19 2009
    Put your stock airbox back in, and next time run him on some twisties.
    '11 S4 6MT
    '58 Auto Union 1000
    '60 Auto Union 1000 SP
    '54 Corvette
    '64 GAZ 69M
    '47 Lincoln Club Coupe
    Atlas R-Line
    IG @this_is_r0b
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    Quote Originally Posted by Brettannica View Post
    LOL
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
    Veteran Member Four Rings blai76's Avatar
    Aug 25 2011
    planes, trains and automobiles.
    San Francisco, CA
    Nice reference to another certain thread...
    Bob
    2008 B7S4tip Avant, 1998.5 B5A4tip 2.8L V6 (retired)
    Mar 11 2015
    He passed me when we were around 110mph. I was looking up the trap speeds on those New rts, I believe they do trap higher than ours.. So it makes sense I guess.
    Nogaro B6 s4
    Mar 11 2015
    I guess now I need to add some more performance upgrades to blow those away. I've raced the older ones and they were nothing compared to the New ones.
    Nogaro B6 s4
    Veteran Member Three Rings noob5's Avatar
    Dec 09 2007
    As previously mentioned, you have to account for awd vs rwd drivetrain loss.
    Btw it's spelled nOgaro...just sayin'.
    '13 allroad Monsoon | APR K04/hfc/downpipe/FMIC | H&R | 034
    '07 RS4 Imola | JHM 93/Stg4 clutch/Shifter trio/Intake spacers | KW HAS | 034 t-mount/linkage arms | Stoptech rotors/pads | Milltek DP's | ECS H-Pipe/motor mounts/rear diff mount
    '12 VW T-Reg
    Gone:
    95 90 SportQ Laser
    99.5 A4 2.8Q Volcano Mica
    02 S4 Santorin
    04 allroad 2.7T Alpaka
    10 Q5 Brllnt Blk
    Jan 14 2009
    Audi's
    That's a little disappointing because are S4 stock runs 0-in mid to low 5 sec range and with your list of mods should be no slouch. The cool thing is your cars 10+ yrs old and is still superior to that crappy thing regardless lol
    Mar 11 2015
    Yeah I figured. It's not like he left me sitting. It took him forever to pass. Not even launching with launch assist I still left him by quite a bit. My passenger thought the dude messed up.but the rt is auto.
    I guess it's time to add some more power, what do you think I would benefit more with.. Stage 4 clutch and flywheel or ported intake manifold?
    Nogaro B6 s4
    Senior Member Three Rings blocke's Avatar
    Jul 26 2013
    1990 BMW 325i (sold), 2006 VW GTI (sold), 2006 A4 S-line (sold), 2014 Jetta SportWagen TDI
    Temecula, CA
    Rofl. You fuckin said it!
    Performance: Fast Intentions 12" resonated cat back, ECS Snub Mount, JHM LTW Crank Pulley, JHM IM spacers, Optima Red Top, Dimple Oil drain magnet, 034 engine mounts,
    Suspension/Brakes: JHM LTW rotors front & Rear, Hawk HPS Pads, VMR V708's, H&R Sport springs, 034 strut mounts.
    Visual: Lamin-X on headlights, 20% tint , ZIZA city LEDs, Ziza License place LEDS, Interior LED conversion, R8 oil cap, 996 coolant cap
    Instagram: lockebrian
    Veteran Member Four Rings pwest15's Avatar
    Sep 15 2013
    2017 S3
    Denver, CO College Station, TX
    Quote Originally Posted by nagarob6s4 View Post
    Neither. You want a supercharger
    Mar 11 2015
    That's actually why I'm planning on getting the stage 4 clutch. Either going with the nos kit or supercharger...
    Nogaro B6 s4
    Sep 15 2013
    2017 S3
    That's gonna be so much fun man. YOu'll be able to launch so hard. Why not go with a JHM R clutch though?
    Mar 11 2015
    I was kindve worried about daily drivability. In Charleston there can be a lot of traffic.. Is there a big difference between the R and stage 4?
    Nogaro B6 s4
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    Your passenger cost you how many lbs? Awd is heavy, shed as much weight as possible. Full sized spare is 50lbs to lose if your carrying that. Floor mats and associated other miscellaneus junk can really add up.
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
    Mar 11 2015
    Yeah I already have the spare removed and tools. Red top optima. Lwfr. 23lb wheels. Cat back and downpipes. As I understand it those items really drop most of the weight..
    Nogaro B6 s4
    Veteran Member Three Rings dolphin B6 S4's Avatar
    Dec 05 2011
    Powerstrokes, LS' and VAG
    Chicago surburbs
    I did a 40 roll with an 09 challenger RT when I was stock and it was about dead even. Apparently I got the jump which put me ahead about half a car but he never caught up.
    2013 White Diamond 6M CTS-V Sedan - Would be easier to name the stock parts left
    1993 Emerald Green URS4
    1992 Tornado Red Corrado SLC
    -SOLD- 2004 Dolphin Grey S4 - Stern motor mounts | JHM IM spacers w/K&N | FI Non Res CB | Trexturk Downpipes | JHM 93 Tune | Apikol Snub | RS4 Pedals |
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    If you want to make sure that doesn't happen again..
    ..Just tell us when
    Jan 14 2009
    Audi's
    Intake mani really wakes the car up!
    Veteran Member Four Rings SpoolBus's Avatar
    Aug 07 2013
    ATL/GA
    oh gawd I just crapped a little...sweet baby jesus
    Sounds like my "altercation" with a Merc E500 2 days ago..same deal at 110 he walked away..poof
    BTW Jake he could prob buy a charger for the price of your charger...charged..charging...RT
    Mar 11 2015
    Wow a e500? Damn you awd
    Nogaro B6 s4
    Veteran Member Three Rings s4ski's Avatar
    Jul 01 2013
    2005 S4 Avant, Skiis
    Anchorage, AK
    Quote Originally Posted by Jake@JHM View Post
    ..Just tell us when
    Here comes the candyman...
    Mar 11 2015
    So quick update I know it's lame but I used perfexpert (got good reviews nicely set up and engineered.) to just get a baseline of est whp and torque. Did 5 runs and they were showing 280-304 whp/250-275 wtq. That's led me to check out the intake manifold flap because it's missing torque. I found my flap is sticking.. It's very hard to move by hand. And doesn't seem to modulate all the way. So I raced the Dodge with a sticking flap.. Is what it seems. I'm placing my order Monday for a new jhm upgraded manifold. :)
    Nogaro B6 s4
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    ugh so jelly! you will need to post the nsfw pics when you receive the IM
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Mar 11 2015
    Oh most definitely I would've had it ordered but jhm closed at 5pm and I was going to use some gift certs. Lol sent my email a 10 minutes late. Now I have to wait the weekend doh!
    Nogaro B6 s4
    Mar 11 2015
    So my order is in for jhm manifold. When it comes in I'll post up some pics.
    Nogaro B6 s4
    Mar 11 2015
    Finally got it in. This is what It looks likes straight out of the box.
    Let me know if you want any other pics before it goes in
    Nogaro B6 s4
    Veteran Member Four Rings Axel-'s Avatar
    Jan 29 2011
    2006 JHM Stg 1 SC'd S4 Avant 6MT
    Toronto, CA
    If you plan on going sc or nitrous, I would recommend JHM's R series clutch setup rather than the stage 4. Ask them about it when you're ready.
    Sprint Blue B7 S4 Avant 6MT - 421whp/350wtq - Review of all my mods
    JHM Stage 1 SC - JHM IM - JHM 5R clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - JHM shifter - Trexturk DP - Magnaflow CB - Hotchkis RSB - JHM IS - 034 Adj. FUCA - STE Gauges
    Oct 11 2007
    Suburbia
    You should really consider putting the stock airbox back in.
    12' R8 Daytona/CF V10 6MT
    07' RS4 Daytona/Panda
    Mar 11 2015
    I don't have the stock airbox when i purchased the car this is what It had. I'm trying to source one. I don't have that Aux radiator on that side tho so hopefully it's not pulling in to much hot air.
    Nogaro B6 s4
    Sep 16 2013
    Pa
    Soo pretty. I want one. Just curious though if your Charger friend is upgrading parts too, while your not lookin.
    Mar 11 2015
    Nope.. He came over and asked what I was doing. He said he wants to buy a gtr now lololol
    Nogaro B6 s4
    Mar 11 2015
    Yeah it's fast now. I'm amazed. Completely worth it. Also did the oil check valve. This motor was swapped into my car last year by a shop that blew my last motor. I can't believe it was that dirty for 70k on it.
    Nogaro B6 s4
    Jan 14 2009
    Audi's
    Nice work!! How long did it take you...? Was a real PITA for me haha
    Mar 11 2015
    Got the package in at 10am finished at around 4 pm. Non stop lol.. The clips were annoying that's about the only thing I had trouble with.
    Nogaro B6 s4
    Mar 11 2015
    Quote Originally Posted by Axel- View Post
    There a big difference between R and stage 4? I'm sure daily drive ability suffers correct?
    Nogaro B6 s4
