Results 1 to 40 of 50
    Sep 17 2005
    Fremont, California
    Introducing the 034Motorsport B6/B7 Audi A4/S4/RS4 Rear Diff Carrier Mount Upgrade!
    Introductory Special: ENDED
    We're pleased to announce an exclusive Introductory Special on the new 034Motorsport Billet Aluminum Rear Differential Carrier Mount Insert Upgrade Kit for the B6/B7 Audi A4/S4/RS4 Quattro!
    034Motorsport Rear Differential Carrier Mount Insert Kit, B6/B7 Audi A4/S4/RS4, Billet Aluminum
    Retail: $95.00 + Shipping
    Introductory Special: $85.00 + Shipping
    Introductory special pricing is limited to the first 30 buyers. Thank you for all of the interest, and we hope you enjoy the upgrade!
    034Motorsport is please to present our new Billet Aluminum Rear Differential Carrier Mount Insert Upgrade for the B6/B7 Audi A4/S4/RS4! The factory Audi rear differential carrier bushings have voids in the rubber damping medium, which results in excessive rear differential movement (twisting) under load. This movement allows for unwanted drivetrain slop (and sometimes clunks) than can be observed when accelerating, decelerating, and shifting.
    These billet aluminum inserts are designed to fill the voids in the factory B6/B7 Audi A4/S4/RS4 rear differential carrier mounts, and limit rear differential movement without sacrificing ride quality or introducing any additional noise, vibration, or harshness into the cabin. By filling the voids in the factory mounts, these inserts eliminate the associated slop and ensures that you're experiencing smoother shifting and throttle transitions, and an improved driving experience.
    Installation is very simple, can be performed in minutes, and is completely reversible. This upgrade is the easiest and most effective way to limit unwanted differential movement, improve throttle response, and increase shifting performance on your B6/B7 Audi A4/S4/RS4 Quattro.
    Features:
    • CNC-Machined Billet Aluminum Construction with Clear Anodized Finish
    • Application-Specific Design Featuring Stainless Steel Securing Washers
    • Engineered to Fill Voids In Factory Rear Differential Mounts
    • Drastically Reduces Rear Differential Movement During Shifting, Acceleration, and Deceleration
    • Improves Shifting Feel, Resulting in Crisper Shifts
    • Will Not Cause Additional NVH Transfer Inside Cabin
    • Easy, Straightforward Installation Takes Minutes!
    What's Included:
    • 034Motorsport Billet Aluminum Rear Differential Carrier Mount Insert Pair
    • High Strength Stainless Steel Securing Washer Pair
    Fitment:
    • 2002 - 2005 Audi A4 (B6) - Quattro Models Only
    • 2003 - 2005 Audi S4 (B6)
    • 2005.5 - 2008 Audi A4 (B7) - Quattro Models Only
    • 2005.5 - 2008 Audi S4 (B7)
    • 2006 - 2008 Audi RS4 (B7)
    Installs Into:
    • 8E0 599 257K / 8E0599257K
    Installation Instructions:
    Please don't hesitate to contact us via PM or email if you have any questions.
    Click Here to Order!
    Jan 24 2008
    Pennsylvania
    Order placed!
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Dec 07 2009
    East Coast
    ^+1
    Forget the B8, keep the V8!
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    I'm in.
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    order placed
    PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
    2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Order placed!
    2019 SQ5 Prestige
    Established Member Two Rings Four-Play's Avatar
    Nov 07 2008
    Asheville NC USA
    Just placed my order! Thanks, again, 034
    Shawn
    Veteran Member Three Rings Newbie6's Avatar
    Jul 30 2012
    2010 Mustang GT/Saleen Supercharged
    Port Hueneme, CA
    Order was placed!
    IE CAI, JHM Downpipe, Turbo Muffler Delete, ECS DV spacer, APR Coil Packs, JHM FMIC, JHM Stage 2 with TCU tune
    Sep 17 2005
    Fremont, California
    Wow, we didn't expect these to be quite so popular! We're almost sold out of the ones we made for our initial run, but will continue to honor the introductory price for a few more days.
    If you see a note saying they're out of stock, it should only be about two weeks for us to machine more, get them anodized, and kit them up. We still have about 10 left.
    Thank you for all of the orders!
    Dec 01 2007
    San Jose CA
    Das hot.
    Jan 24 2008
    Pennsylvania
    Received the email saying they've already shipped out. Well executed product rollout 034! That's they way we like to roll
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Placed my order
    USP CLUB MEMBER #34
    Veteran Member Four Rings EvoRam's Avatar
    Jul 30 2012
    2006 Imola S4 Avant
    Tacoma
    Jackal Tuned / BMC Panel Filter / Tweetler 93mm TB / SAI Delete / JHM IM Spacers / AWE 2.5" Downpipes / Corsa RSC / JHM SSB / 034 Zero-Gap Snub / 034 FSB Links / SD Mounts & Diff Inserts / 034 RSB & Links / Bilstein Sports / Neuspeed Springs
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    got mine in today... cant wait to install them
    Sep 17 2005
    Fremont, California
    We are sold out of the first run, and expect to have more back in stock in approximately 2 weeks. I will be leaving the introductory price active through the end of the day today.
    If you want to save $10 and don't mind waiting for the second run to come of our machines and go out to anodizing, make sure to order before the end of the day today!
    Dec 07 2009
    East Coast
    Quote Originally Posted by TarlCabot View Post
    Got mine as well
    Sep 17 2005
    Fremont, California
    Thank you for all of the orders! The Introductory Special pricing has ended!
    We're looking forward to your feedback and reviews; feel free to post your experience in this thread or leave a review for the inserts on our website.
    Jul 30 2012
    2006 Imola S4 Avant
    Tacoma
    That was quick!!! Can't wait to install these!
    Sep 17 2005
    Fremont, California
    Thank you to everyone who is waiting patiently for the next run! Our Haas Vertical Mills are cranking away on these things.
    Anyone gotten the install finished up yet and have a review?
    Sep 17 2005
    Fremont, California
    Thank you for the orders! The second batch of these should be ready to ship next week. We appreciate your patience while we're getting caught up on production!
    On a related note, I have enabled USPS shipping options to Canada, and our DHL shipping module has been updated, so there are a few more international shipping options available.
    Sep 17 2005
    Fremont, California
    These are back in stock and ready to ship, so keep an eye out for a shipment confirmation email! We got them done a week ahead of schedule!
    Sep 17 2005
    Fremont, California
    Just a heads-up... We sent out a brief survey to the first 30 people who ordered these. It's very quick to fill out (only 8 questions) and if you respond, you'll be entered to win a $50 034Motorsport Gift Card!
    These 2002-2008 Audi A4/S4/RS4 Quattro Performance Rear Differential Mount Upgrade Kits are on the shelf and ready to ship!
    Sep 17 2005
    Fremont, California
    Thank you for all of the orders over the weekend!
    Sep 17 2005
    Fremont, California
    Any more reviews coming in? We've seen a lot of great feedback coming in through the surveys we sent out, but it would be great to hear some more impressions from owners.
    B6/B7 Audi A4/S4/RS4 Rear Diff Mount Upgrade
    Sep 17 2005
    Fremont, California
    If you're still on the fence about these, check out the latest review on Nick's Car Blog!
    034 Motorsport Rear Diff Carrier Mount Insert Kit
    Jul 30 2012
    2006 Imola S4 Avant
    Tacoma
    Introducing the 034Motorsport B6/B7 Audi A4/S4/RS4 Rear Diff Carrier Mount Up...
    Quote Originally Posted by 034Motorsport View Post
    Finally got around to installing these (ordered them up during the initial intro price) and they completely eliminated whatever drive train slop I had left. The 034 inserts were a nice finishing touch to the Apikol rear diff mount I had installed already! I have only had them in a few days but absolutely would recommend this mod for anyone looking to minimize notchy shifting. I could def tell a big difference in low rpm shifting where i had a lot of notchiness. As Nick also mentioned in his write-up I would recommend using some lube (I used Wurth Rubber Care) to help install these.
    Dec 01 2007
    San Jose CA
    Thanks for the info, gotta get mine installed too.
    Jan 24 2008
    Pennsylvania
    I finally installed mine yesterday. I found it was easiest to remove the rear sway bar to get enough access to properly torque the bolt. The other trick to the install has to do with the length of the bolt. On the opposite end of the bolt, there is an 18mm nut and washer. After loosening the bolt (which ultimately results in removing the nut completely from the bolt), inserting the bushing into place, and then attempting to install the washer and thread on the nut, I found that there was not enough exposed threads of the bolt for the nut to grab with the washer in place (since the bolt was barely long enough). So what I did was first thread the nut onto the bolt without the washer in place, just enough to pull the bolt a little further through. Then, with my ratchet holding the bolt, I again removed the nut, slid on the washer, and then re-installed the nut, tightened, and then torqued the bolt to spec. No problem.
    Other than this minor detail, the install was easy.
    Sep 17 2005
    Fremont, California
    Happy Friday! Anyone installing some of these inserts this weekend?
    Quote Originally Posted by Turbavanttro View Post
    Thanks for the tip! One trick our techs came up with (they're smarter than I am when it comes to installing stuff) is to back the bolt out so that the nut/washer is off, slip the insert in, then slip the washer between the bolt head and insert.
    Once that's done, you use a pry bar (the sway bar is used for leverage) on the bolt head to push the insert in. While you're pushing it in with the pry bar, reinstall the washer/nut on the other side. It seems to speed up the process quite a bit.
    Sep 17 2005
    Fremont, California
    Thank you for the continued orders! We're already busy machining another run of these in our CNC Machining Department.
    Sep 17 2005
    Fremont, California
    ...and these are once again back in stock and ready to ship!
    Sep 17 2005
    Fremont, California
    We have a version of these coming to the B8 Audi A4/S4/RS4, A5/S5/RS5, Q5/SQ5 & C7 Audi A6/S6/RS6, A7/S7/RS7 very soon! If you happen to also own either of those platforms, then keep an eye on our website for the release!
    Sep 17 2005
    Fremont, California
    Happy Friday! Just helped one of the guys here install a set of these in his car last night. A pry bar and some silicone lubricant makes the job a breeze! I think it took us longer to rack the car than it did to install the inserts.
    - Laszlo
    Click Here to Order the 034Motorsport B6/B7 Audi S4 Rear Differential Mount Bushing Upgrade
    Sep 17 2005
    Fremont, California
    Bump! These are the perfect upgrade to go along with your Apikol Rear Differential Mount!
    While the Apikol mount replaces the front-most mount for the rear differential (circled in red below), the 034Motorsport Rear Differential Carrier Inserts install into the two rear-most mounts for the rear differential carrier (circled in blue below), to prevent twisting of the rear differential housing under load, between shifts, and during launches.
    Sep 17 2005
    Fremont, California
    Happy Friday! We've had some AZ Members interested in a package deal with these Rear Differential Carrier Inserts and our Density Line Engine Mounts & Transmission Mount. Any other takers?
    Click Here to Learn More About Density Line Mounts
    Sep 17 2005
    Fremont, California
    Jul 30 2012
    2006 Imola S4 Avant
    Tacoma
    Sep 17 2005
    Fremont, California
    Bump! Any more reviews coming in for these? I know that quite a few AZ'ers are running them.
    034-505-2015
    Sep 17 2005
    Fremont, California
    Thank you for all of the orders this weekend!
    Both our Rear Differential Carrier Inserts and Apikol Rear Differential Mounts are in stock and ready to ship! This is the perfect combo to tighten up the rear differential mounts on your car, improve performance, and get rid of the dreaded "diff clunk"once and for all.
    Established Member Two Rings Sleepin On 18s's Avatar
    Aug 31 2015
    '07 RS 4 _____'12 Touareg Lux
    Baltimore
    Installing the trans mount carriers next week!!! Looking into the diff mounts as well.
    Wanted to know what sick pipes are you running on the RS4 in this pic?? I can't tell which ones they are - they look great!!! Thanks 034
    '07 RS 4 // DGP, Stoptech Aero, JHM Trio, 034 Mounts, Res delete, Hella Horn (dreams do come true!!)
    '06 A4 3.2L S-Line // Rare Blk/Blk/Blk 6spd, Alum Trim, Nav/BT (amazing car)
    '03 A4 1.8t // Blk/Blk 6spd (even w mods, didn't love 4 cylinders)
    '98 A4 2.8L // Blk/Blk 5spd (heavily modded, won some shows)
    '96 A4 2.8L // Pearl Wht/Blk 5spd (first love, Quattro for life)
