Results 1 to 11 of 11
    Active Member Two Rings 1Silver's Avatar
    Sep 21 2011
    NJ/Bergen
    Battery Replacement
    2000 B5 S4
    how many of you have replaced the battery for another brand and why did you get that specific one.
    i'm looking for an Optima Red top but i've been told it won't fit.
    Any suggestions?
    Thank you in advance.
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    Get an Interstate battery, they are the best out there.
    Registered User Four Rings PAT@RSW's Avatar
    Jul 02 2008
    BMW M4, SQ5, SL65 AMG
    Green Brook, NJ
    Interstate produces many of the "OEM's" Batteries ;) Just a different sticker kit for the specific manufacturer!
    Mar 31 2015
    NYC / CT
    What did you end up getting? And did you do the install yourself?
    I need a replacement battery for my A6 but came across some posts about "reprogramming being required to recognize devices"... sounds too complicated and overkill to simply replace a battery!
    Any feedback would be awesome!
    Cheers,
    BB
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    Quote Originally Posted by BBear View Post
    Cheers,
    BB
    What year/generation A6? We're happy to help if you don't mind popping into NJ (we have a location in Clifton - ~15 minutes from NYC)
    Dec 05 2007
    I run an optima red top in my b5 a4. Same install and you just need to figure your own way to mount it. I did. And if going with optima, you want a yellow top for your location. But truthfully, optima is trash ever since they started manufacturing in Mexico. Go with something different. I'm currently on my third one under warranty. When this one kicks the bucket, not sure what I'll run next.
    Mar 31 2015
    NYC / CT
    I run an optima red top in my b5 a4. Same install and you just need to figure your own way to mount it. I did. And if going with optima, you want a yellow top for your location. But truthfully, optima is trash ever since they started manufacturing in Mexico. Good with something different. I'm currently on my third one under warranty. When this one kicks the bucket, not sure what I'll run next.
    I've had Yellow tops on my Maxima and same disappointment... Surprised how they didnt last as expected.
    Thanks for the feedback on the installation... I suspect on the A6 should be an easy swap as well.
    BB
    Mar 31 2015
    NYC / CT
    Quote Originally Posted by Sales@DriveAuto View Post
    This would be for a 2007 A6, I suspect C6 A6?
    Could you send me a quote for a battery replacement? If reasonable I would not mind driving.
    Thanks,
    BB
    Apr 13 2012
    Thanks,
    BB
    Yep, C6. Will shoot you a quote tomorrow!
    Mar 31 2015
    NYC / CT
    Thank you mate!
    Sep 21 2011
    NJ/Bergen
    I ended up going with a Optima Red top. Easy to drop in I just tweaked the mounting bolt location. Yes disappointing on their durability but I noticed when you get them they have a built date in them and most stores that have them are usually a year old sitting on their shelves.
