Results 1 to 6 of 6
    Mar 27 2012
    1980 Harley Sportster
    Ocean city, nj
    Ambient temp sensor question
    While working on my car today I broke the wire going to the ambient temp sensor, too close to the plug to try and fix it. Does anyone have a part # for the wired side? Or know what kind of plug it is so I can order one and wire it up?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    You can order replacement plugs and pins from ECS: Clicky click
    Feb 27 2011
    Winnipeg
    IIRC its the same as the brake pad wear sensor connector/brake fluid sensor connector, I always cut them off when I change pads and save them for situations like this.
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    Quote Originally Posted by seanf86 View Post
    Ha! For real!!
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by lyates1987 View Post
    Ha! For real!!
    My bad brake pad wear sensor is the female connector, you need the male connector that plugs into the sensor, still the same connector as iat/brake fluid level sensor tho
    Sep 17 2014
    Lakeway
    I was just agreeing with you on saving those connectors. My car has fouled a few and I've had to de pin and re pin a few times for better connectivity.
