Results 1 to 8 of 8
    Veteran Member Three Rings piotrowr's Avatar
    Jul 18 2008
    Scottsdale
    Brake Service Labor
    I was quoted $282 out the door by a reputable indy shop for labor cost only as I'm supplying everything.
    Oil and filter change
    front rotor and pad replacement
    rear pad replacement.
    Sounds reasonable? I just had my brake fluid flushed 6K miles ago so I was informed that would not be necessary.
    2010 A4 Avant Prestige - 19" Sport Package, Quartz Gray Metallic
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    I think that sounds very fair, at least compared to labor rates in my area.
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    Sounds very good, I think a synthetic Oil change with Mann filter is around $90 (including the oil and filter). Are they turning the rear rotors for you as well?
    Veteran Member Four Rings oascom's Avatar
    Jan 08 2013
    New Jersey
    Instead going to shop for 280$ u can get jackstands/jack/oil extractor and still got $ for beer. Diy and knock it out in 3-4h with beers in between and call it a day
    APR, Eurocode, AWE, P3, aFe , CTS, Spulen, H&R, 034Motorsport, STaSIS
    Jul 18 2008
    Scottsdale
    Thanks for the feedback. Don't have the facilities for this work plus not allowed to perform car repairs in my association otherwise I would consider it. I do need to confirm about the rear rotors. They look in good shape still so once I drop off we'll discuss. Also going to have them rotate wheels while they're off.
    Oct 10 2012
    Zionsville and Saint John IN
    Quote Originally Posted by piotrowr View Post
    That is a very fair price, sucks you can't do it on your own though. Although you would have to add in the cost of a vagcom cable to extract the rear caliper pistons.
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
    Senior Member Two Rings Classy's Avatar
    Feb 02 2014
    NH
    Good quote. Especially if you dont want to do it yourself or the hassle of it.
    Sep 09 2010
    Destin, FL
    If you're getting the front rotors replaced, replace the rears too. You don't put 30k on your tires and just replace the front right? No. But I would do it yourself, you'll save and you will get to know your car better so if you ever have an issue, you can fix it. If you don't have the time or knowledge, get a friend that can help and if not, the price they gave you is pretty good.
