Results 1 to 4 of 4
    May 28 2011
    Eugene,Oregon
    anything i may be missing
    I have a 2001 Audi S4 and the timing belt with every thing else has been done. I never really drive it hard just when passing or merging into traffic.I need to take care of my very leaking auxiliary pump. Im also looking to replace my valve cover and intake manifold with powder coated Germanys flag colors. Also the car is jerking when I'm trying to build boost which I'm hoping i find the boost leaking while doing this job.
    I have both valve covers and gaskets
    intake and spacers
    auxiliary water pump with both hoses
    So couple of question.Would it be best to also replace the pcv spider hose. Ive seen some people doing there on design just want to get some ideas on whats best out there. am i missing anything else while doing this job and will i need any specials tools or small/big vacuum hose to replace? Also where is best the place to buy factory like hose clamps
    thanks
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    You should have just done an aux pump delete instead of getting a new one (search will show you how).
    Jerking car - log and see if there are codes.
    Clamps - ABA Swedish clamps are easier than OEM Oetiker and hold tight.
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    May 28 2011
    Eugene,Oregon
    Im also thinking about doing some injectors but not sure if i should go with bigger. I'm only running ko3s(exhaust and other upgrades are done just not turbos). or just new stock ones
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Injectors won't matter unless you plan on running E85, then you would also need a fuel pump.
    Stock injectors are fine for any pump gas stage 2+ tune.
    Hesitation could be misfires, scan.
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
