Results 1 to 6 of 6
Thread: Audi A3 TDI
    Mar 07 2015
    michigan
    Audi A3 TDI
    Im thinking about buying a 2009-2012 Audi A3 TDI, I was just wondering what are some of the common problems with the 2.0 turbo diesel engines? Did they make manuals for those years? Does the TDI have the Quattro awd? And should I not get the TDI and stick with the normal engine? Any feed back will be helpful, thank you.
    Established Member Two Rings Euro Vs Earth's Avatar
    Jul 31 2010
    Atlanta GA
    It's a good car, the wife and I like it. Avg mpg around 34-35. Unfortunately no traditional manual transmission or Quattro. Dumb...
    Anyway as for common problems, none I'm aware of that aren't a result of neglecting preventative maintenance.
    I'd recommend getting one. Plus there are plenty of mods out there to empty that wallet
    Current: - 09' A6 Avant 3.0t Gray/Blk, 5%tint
    Sold: '10 A3 TDI S-Line, 20% ceramic tint, 312mm front rotor upgrade, JL 10w3 w/WickedCAS custom box.
    B7 3.2Q Black/Beige.
    97 Orvis ZJ
    84 300zx turbo
    Dec 29 2013
    I'm in the same boat and was wondering if there were any issues with the TDI motors and it replacement parts are going to cost an arm and a leg. LOL
    -B
    Feb 17 2015
    United States
    Just got an 2012 about a month ago. Its a good car not many options like for powertrain like Euro Vs. Earth mentioned. All have a DSG, i think some come with paddles and thats about it.
    Apr 03 2011
    SF
    If the DPF goes bad, which it will in time it will and its a costly part. Exhaust upgrades for diesels are beautiful in the fact that they increase HP and torque and improve gas mileage. A turbo back exhaust upgrade from Rawtek/Malone can double your torque putting you close to 400lb ft. and it eliminates the DPF/EGR problem and the car will run better. Or you could go nuts and look @ Darkside and go 300HP+
    Mar 15 2014
    nys
    Found this on sale for a TDI. If your looking for reliable power and better economy.
    http://forums.tdiclub.com/showthread.php?t=436011
