Results 1 to 10 of 10
    Oct 01 2007
    S. Florida
    Suspension bushings, boots ... possible?
    My front control arm bushings/boots seem to be worn, and after spending a couple of hours searching and reading I can't find any info on replacing the boots or bushings. It seems most members in this forum replace all the control arms, ball joints and end-links with complete kits. I'm assuming that once the bushings or the little rubber boots start to break down the control arms and end-links must be worn out, so maybe it just doesn't make sense to R&R the bushings. Any thoughts on this, or is there a way to fix them?
    Here is what my lower front control arms look like with 100k miles. These are original OEM parts, never replaced yet:
    Left side
    Right side
    So, is it consensus to just get a new control arm kit, both upper and lower, and also replace the end links? Or is there a cheaper, easier route?
    Feb 24 2004
    Minneapolis
    I've pressed my share of bushings and done my share of control arms. So for the work it takes to remove a control arm, press in a new bushing, then put it back in only to have the ball joint go a couple months later.........no thanks.
    Years of B5 experience here, and I once bought a whole kit just to save money, but still only did them as they went bad. Seems like the upper fronts give up sooner than the lowers. The sway bar links? When they start popping I change 'em.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Oct 16 2008
    South Florida - Ft Lauderdale
    Just replace the assemblies, you will save time and money in the long run
    Phil
    Senior Member Three Rings vtwinjunkie's Avatar
    Aug 10 2013
    Various motorcycles
    NOVA
    What seems to be the general consensus on mileage that suspension components fail on our A4's? Or do we know?
    Mar 24 2013
    Oakdale, CT
    Depnds on environment and usage. I swapped mine at about 125k and they were far from shot. It was a "while im in there" sort of thing
    -Adam
    Aug 10 2013
    Various motorcycles
    NOVA
    Yea that makes sense. I thought I read somewhere that they usually go around 100k around normal conditions but I cant remember
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    Quote Originally Posted by vtwinjunkie View Post
    50K. Why? Because that's when the warranty is up!
    Front and rear upper control arm bushings last between 50-70K. They take the brunt of the punishment. Lower control arm bushings can last 100k+
    The ball joints can last 100K+ as long as the boot is intact. These are wear items.
    OP, I can guaranty that you need a complete front end refresh. Control arms, end links, sway bar bushings, inner and outter tie rods. I would even replace the rear upper contol arm bushings and outter hub bushing.
    Oct 01 2007
    S. Florida
    Thanks all. I think I have to take a closer look at the rest of the suspension items, both front and back. Aside from a faint creaking as I back out of my driveway, I'm not experiencing any issue with suspension. Tire wear is very even, alignment seems to be okay, handling is not sloppy, and bearings have no play.
    If I need to replace front and back suspension parts, I'm not sure I would want to overhaul everything all at once. I'm almost beginning to regret keeping the car if I have to continue to pour more money into it at this pace. I've put around $2500 into it in the past 3 months, and now it seems I'd need to put another $1500-2000 into suspension, plus I know my brakes and A/C need attention. So now we're talking over $5000 in a 9 year old car with over 100k miles. Tough to justify.
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by sfl_A4 View Post
    You really have to do your own work if you're going to drive an old German car. It's the only way you can make sense out of it.
    Aug 10 2013
    Various motorcycles
    NOVA
    Quote Originally Posted by mtroxel View Post
    This^^^^
    I have saved thousands in doing my own work...
