Originally Posted by
goalieman24
So is the delayed start-up a thing? More importantly, a fixable thing?
If I just key my ignition on, the gauge does its sweep almost immediately. But if I skip keying it on first and just start it, there is a few seconds of lag before the gauge comes to life. I figured this was just how it was and never bothered to look into it.
The turn on delay is a known issue with the VW Mk5/6 platform.
Only recently have we been receiving calls from a few B5 owners describing a turn on delay and we are unsure as to what is causing it, since power tap locations shown in DIY have been pretty much the same for years.
If you can post up a video of the "lag" you are seeing it would help determine if it a turn on delay or something else.
Here are some videos of what the turn on delay looks like:
http://podi.ca/turnondelay.aspx
The boost gauge when activated does not startup right away because the initial power suppled on the switched +12v wire was interrupted, so the gauge detects this as the car being turned off so it begins its shutdown sequence (needle sweeps to -30 and the needle is already there, backlight turns off, needle lighting turns off, needle flashes once to say "bye"), once this is completed the gauge detects the restored power on the switched +12v wire and starts up again, this time it completes the startup routine and displays a reading.
