Results 1 to 9 of 9
Thread: Help!
    Nov 01 2012
    WA
    Help!
    I have a 07 S4. Car sat for a couple months, started it up and I have oil coming from my exhaust with blue smoke. Done some research and can't really find anything. Any help would be greatly appreciated
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    how many miles ? Probably NOT a big deal... because it sat for such a long period, probably just oil leaked down through the valve guides
    if it continues or you notice considerable oil usage between oil changes, you will probably need to get a compression/leakdown done on her to figure out where the oil is coming from
    of course it would not hurt to go ahead and change out the PCV because it is known to cause this problem as well... cheapest alternative, just go with OEM replacement... NOT the cheap one imho
    PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
    2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
    Nov 01 2012
    WA
    I only have 25k miles. Changing PCV now. Consuming a lot of oil
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Quote Originally Posted by LeggoMyEGGROLL View Post
    that would be the earliest that i have seen for consumption, hopefully its just that PCV stuck... just cant see an 07 with 25k miles having scored cylinder walls or bad valve guides/seals
    g/l
    Nov 01 2012
    WA
    That's the exact thought my mechanic has. Fingers crossed
    Nov 01 2012
    WA
    Not PCV. On to more tests
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    if it was valve stem seals leaking during storage , the blue smoke in the exhaust would have stopped after a couple minutes ,
    but now you've been driving it for a day or two and it's still burning alot of oil.
    PCV is good , I guess cylinder walls are good ( only 25k miles),
    I can't see why it would burn oil that bad
    Check your oil level ,maybe its overfilled
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    what was the condition of the car before storage? i'm assuming no oil consumption whatsoever, also have you checked vagcom for codes?
    My guess is: some of your piston rings are stuck causing. hopefully not scoring your walls...
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Nov 01 2012
    WA
    My car is in excellent condition. First time having any kind of engine problems. Only once have I had to add oil and that was a 1/2 quart when I first bought the car. Pressure test and valve check tomorrow. Fingers crossed
