Results 1 to 6 of 6
    Veteran Member Three Rings zps123's Avatar
    Apr 20 2012
    MK1 Rabbit 2.0 16v
    Adjustable Control Arms Damaged Wiring
    So I was driving in the canyon today with couple friends. I must have cornered too hard and the suspension fault light came on. I scanned it and it says the electric circuit for the suspension leveling sensor has problems. I looked underneath that plastic cap covering the control arms and apparently one of the wires has been pretty badly damaged. I'm wondering how much the repair would be, and I think I saw something from AWE that reroutes the wires but couldnt find it anymore. Has someone came up with a solution for this at all?
    2015 Audi SQ5
    Brilliant Black|BO|Black Nappa|B&O|NAV|KW HAS
    Past: '14 Audi S4 | '11 VW Tiguan
    Aug 29 2013
    2014 Audi S4, 2015 Audi A3 Prestige
    DFW
    Quote Originally Posted by zps123 View Post
    http://www.awe-tuning.com/spc-perfor...ontrol-arm-kit
    It's the 4th item down on the page.
    As far as fixing the wiring, I'd find out what gauge it is and then cut the damaged part out. Then just solder a new section in there the length of what you had to cut out. Before that put the same color heat shrink tubing on there and heat it up to cover your exposed wire. After that you could wrap it in electrical tape just to feel more safe, but with the right size heat shrink it shouldn't be a problem.
    2014 Audi S4 - Ice Silver Metallic | Black Alcantara | Black Optics | B&O | Sport Diff | DSG | ADS | Nav
    2015 Audi A3 Prestige - Scuba Blue Metallic | Chestnut Brown | Sport Package | Sport Suspension | Black Headliner (Wife's)
    Apr 11 2012
    most just don't go too low and/or don't go back to factory alignment in the front (camber-wise), I did -1.7 in the front, min spec is -1.6.
    Apr 20 2012
    MK1 Rabbit 2.0 16v
    thanks for the help guys. i did my alignment at the dealer after my last service so it's probably aligned with factory specs. i guess i probably should go with a little more camber in the front to help with this issue and more clearance for the wheels too. im gonna look into soldering the things back together as that doesnt sound too hard
    2015 Audi SQ5
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    soldering isn't that hard to do. just make sure you use some heat shrink to seal the wires. You may have to use some zip ties or some convolute tubing over the wring to help protect it.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    There are 10 kinds of people in this world, those who know binary and those who don't.
