Results 1 to 4 of 4
    Established Member Two Rings tyfoon129's Avatar
    Dec 27 2011
    08 RS4, 13 Golf R, 2001 A4
    Anyone ever had an aftermarket snub mount squeak on them?
    Just did a big engine service. New belts, T belt, IE tensioner, water pump, T stat. The whole works basically. I also threw in a apr snub mount while I was in there. Now I've never had an squeaking sounds before and at first I thought it was just the new belts but it hasn't gone away. It's a very loud squeaking that only occurs while rolling and while under acceleration. Usually between 2-4k. Could it just be the poly running on the snub mount cup? It's driving me insane
    Mar 01 2015
    kansas city
    So, are you using the stock mount or a snub cup fitted to the mount? I have a apr poly in a cup and haven't heard a thing from it.
    Dec 27 2011
    Quote Originally Posted by thesuitguy View Post
    Sorry, APR mount with stock cup.
    Established Member Two Rings siffer's Avatar
    Dec 26 2006
    Huh
    Sounds like a belt if it's at certain rpms. Take us a vid if you can.
    What timing belt did you go with? My gates squeeks but goes away on warm up.
