Results 1 to 6 of 6
    Senior Member Three Rings caldy315's Avatar
    Mar 18 2013
    WJ & WK2 Jeep Grand Cherokees
    Mpls, MN
    Possible to use a ECU from a diferent B6?
    All,
    I have been planning on upgrading to a Stage 1+ tune after riding in a local persons B6 USP. I've recently aquired some TT225 injectors, so I'm shooting for a Stage 1+ tune. Before I start figuring out what company to go with, I was wondering if by chance I came across someone parting out their A4 that had a tune, would I be able to buy and use their tuned ECU with my car? I know the SKC and have programmed my own keys from scratch, so I've done some Vag Commander work.
    If so, do I have to defeat the immobilizer? I would rather not, as that is what doesn't allow just any old key to start the car, at least from my reading. Ideally, I'd have both a stock set of injectors and ecu along with a tuned ECU and larger injectors.
    Figured I would see what this was about before going to APR or another tuning company to get tuned.
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    A ecu from the same year with the immobilizer defeated will be able to run the car with no issues. I ran around with another ecu for about a week while mine was being tuned. Once again, as long as the immobilizer is defeated you are good to go.
    Of course, same engine, same year (maybe) and same level tune so you do not run into any issues - but isnt exactly necessary.
    Jan 01 2012
    2004 A4 Avant
    CO
    Year doesn't matter except for the 02's. 02 ECU will only work with 02's. 03-05 are all the same.
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Mar 18 2013
    Mpls, MN
    Do you have ton defeat the immobilizer though? That's the main question I guess now. Would like not to
    B6 A4 Ultrasport (Dolphin Gray) -- Passed down to brother
    B9 S4 Prestige (Daytona Gray) -- Current
    WK2 Jeep Grand Cherokee Overland (Steel Blue) -- Wife's ride
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by caldy315 View Post
    depends on the tune - some/most will revert to a stock-like mode if the paired VIN changes, so having the SKC doesn't help, immo defeat is the only way. It would be easier just to get flashed with a tune that allows you to switch between stock/performance modes without having to change hardware
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Mar 18 2013
    Mpls, MN
    Quote Originally Posted by Matt Devo View Post
    Figured that might be the case. That's ok, just figured I would check to make sure.
