Results 1 to 16 of 16
    Senior Member Three Rings caldy315's Avatar
    Mar 18 2013
    WJ & WK2 Jeep Grand Cherokees
    Mpls, MN
    Possible to use a ECU from a diferent B6?
    All,
    I have been planning on upgrading to a Stage 1+ tune after riding in a local persons B6 USP. I've recently aquired some TT225 injectors, so I'm shooting for a Stage 1+ tune. Before I start figuring out what company to go with, I was wondering if by chance I came across someone parting out their A4 that had a tune, would I be able to buy and use their tuned ECU with my car? I know the SKC and have programmed my own keys from scratch, so I've done some Vag Commander work.
    If so, do I have to defeat the immobilizer? I would rather not, as that is what doesn't allow just any old key to start the car, at least from my reading. Ideally, I'd have both a stock set of injectors and ecu along with a tuned ECU and larger injectors.
    Figured I would see what this was about before going to APR or another tuning company to get tuned.
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    You can pair the "new" ecu with the car.
    You'll have to pull the skc out of the "new" ecu and have your existing skc to do it.
    The procedure is outlined here under the heading "Engine Control Unit (ECU) Swapping (USED ECU)." Clicky.
    To defeat the immo you would have to open the bin and change some hex and checksum the file, then flash it back to the ecu.
    Honestly it would be easier to purchase an MPPS flashing cable from ebay and purchase a tune from a member here and flash it yourself. No immo voodoo to worry about.
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    Quote Originally Posted by caldy315 View Post
    Not quite, there is over 4000 combinations of Audi key blades out there.
    Mar 18 2013
    Mpls, MN
    First off, not sure why this thread got duplicated. Tried to figure out how to close the other one but couldn't.
    I think I got my answer in the other duplicate thread though, which was even if you do buy a different ECU that is previously tuned, if you try to pair to your car without defeating the immo, the tune will revert back to stock.
    Quote Originally Posted by f1torrents View Post
    I meant, with defeating the immo, if you had the right key but it wasn't chipped right, the car would start and run. At least that's how I understand it. The immo tells the car that the key is legit.
    Quote Originally Posted by csosnowski View Post
    I have no problem pulling the SKC. I did that to make my own key, I have the 4 digit SKC number. But I don't want to defeat the immo. What I want is two ecu's that are (or look to be) for my car's VIN, one stock, one tuned. But it sounds like that's a pipe dream as the tune will erase itself if the VIN doesn't match.
    Feb 17 2004
    Liberty Hill, TX
    buy a second stock ECU, pair it, then get it flashed
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    if you feel your up to the task you put your skc in the new ecu following this
    http://nefariousmotorsports.com/foru...p?topic=2973.0
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Jul 31 2014
    NH
    or better yet if your ecu is stock pull the 95040 immo bin from yours and flash to the new one
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    I have a second ECU I have thrown in my car when I was trying to rule out a lean issue and wanted to rule out the APR tune.
    I dont know what car it came out of but everything worked fine except my cruise control, figured maybe it was in an auto or didn't have cruise.
    Please Drive Right
    Mar 18 2013
    Mpls, MN
    Quote Originally Posted by Matt Devo View Post
    That actually makes sense. Best of both worlds, although the price is still the same, plus the cost of the ECU. Not bad though. If I have an 05, I should be able to use an 03-05 ECU and change everything to my car correct?
    Quote Originally Posted by Pothole View Post
    Pothole, but was yours the tuned ECU or did you put in a different ECU that was tuned? If the latter, than sounds like what I wanted to do.
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    If an ecu is flashed with a tune putting it in another car and pairing it with the new immo information does not re-write the tables that are changed when the ecu is tuned.
    Mar 18 2013
    Mpls, MN
    I was just quoting what Matt Devo had mentioned I think in the other duplicate thread. He said:
    depends on the tune - some/most will revert to a stock-like mode if the paired VIN changes, so having the SKC doesn't help, immo defeat is the only way. It would be easier just to get flashed with a tune that allows you to switch between stock/performance modes without having to change hardware
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    Hmm, I've never heard of that before. It seems odd since there are several ecu's for sale in the classifieds that still have their immo intact.
    Either way, you could do it the easy way and find yourself an AK box ecu (2003+ iirc) and an MPPS cable from eBay. There are members on this board that write good tunes and they aren't $600.
    Jun 02 2008
    My second one is OEM stock Audi tune on it. The one that came with my car has APR's tune on It now.
    Please Drive Right
    Feb 17 2004
    Liberty Hill, TX
    APR and Revo both do it for sure. There's nothing to stop someone from selling a flashed ECU regardless, but the buyer needs to know the potential pitfalls of pairing the immo / learning a new VIN
    Jun 02 2008
    It is possible my "stock tune" ECU has had the imobolizer turned off, I got it from a friend of a friend.
    It would make sense that it was set up like that as the first guy used it for diagnosing issues also.
    Please Drive Right
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    Well that's good info, I was unaware of that previously. Its also retarded that they'd write the tune that way as well.
    I remember when I had my b5s4 and I wanted to have APR do something with the tune, they said sure but you've got to pay us $150 to transfer the license to you before we can even touch the ecu. I declined and flashed a tune from somewhere else myself for next to nothing.
    It seems silly to me.
