Alright so I started tearing into my 01E for rebuild except when I went to slide the selector shaft out it was getting hung up. I looked in from the selector cover side and the second arm thing(not sure what you call them. the things that actually select the gears) was pushed slightly to the right. I tried to pry it back to align all of the arms but it seems to be stuck. I tried rotating the main shaft while prying but still nothing. How do I go about aligning these so I can get the selector out? I'm also unsure of which arms are for which gears. The transmission is used and I was told the 1-2 collar was locked up.
Thanks dudes.
