Recently my drivers side window stopped working. I assumed I had burned out the motor as it was frozen shut the day it stopped working and I had tried opening it quite a few times. I know it is not the regulator or a fuse for sure. I tried replacing the window motor today and got the new motor in and that did not work either. When I put the door back together after replacing the motor, none of the controls work on the door (windows, fuel release, trunk release, etc.). The car also thinks the door is open at all Times even when it is shut. I double checked that everything is put back together the same way and everything is plugged in. I am going to take a look at the wires in the door pillar tomorrow and see if those are split, but would love any advice if this has happened to anyone else? This has become a huge hassle as I can't lock my car and every time I drive I have to listen to beeping for the first 5 minutes of the drive. Needless to say I can't wait to figure out the problem.
