Results 1 to 8 of 8
    Established Member Two Rings Goneau's Avatar
    Feb 15 2015
    Connecticut
    Dreaded random misfires
    So I had a misfire on a cold start the other day, and now I'm having other misfires too.
    I was on the highway in 6th at about 65, went pass and it kind of cut out and felt like a miss, cel flashed, checked it misfire 2 and 6.
    Went to get on it a little bit, and cell flashed again. I currently have a cel for bank 1 sensor 2 o2 sensor and I got another for random multiple misfires last time I got on it a bit.
    Current mileage is 98k timing was done around 65k or so, so I didn't think timing would be a concern. Coil packs injectors and plugs were done a few years back according to Carfax. Any info will help. And no I didn't do a good search yet.
    Sent from my potato
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Exhaust leak? It caused my engine to misfire when flex pieces went bad.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Feb 15 2015
    Connecticut
    Wow funny that you said that, because it does sound like I have a bit of an exhaust leak. It just got a little louder than normal lately
    Sent from my potato
    Jan 17 2014
    New Jersey
    Been there done that. If leak is bad o2 sensors are getting wrong measurments and that might cause misfires.
    Insta: luccamentone
    Feb 15 2015
    Connecticut
    I assumed so, I'm doing o2 this week and possibly coil packs while I'm at it
    Sent from my potato
    Jan 17 2014
    New Jersey
    Id check for leaks first. Maybe o2 sensors are good
    Insta: luccamentone
    Senior Member Three Rings rocket5979's Avatar
    Apr 19 2013
    Fox Lake, IL
    Quote Originally Posted by Lucca M View Post
    His DTC pertained to "Sensor #2" which is the downstream oxygen sensor that only monitors catalyst efficiency. The "Sensor #1" upstream oxygen sensors are what provide short term fuel trim feedback data to the ECU to assist in controlling part throttle fueling.
    OP, do you have piggies on your car or are you still running the pre-cats? Also, have you looked to see exactly what cylinders you are getting misfires on? Is it located primarily on one bank of cylinders or both?
    -Robert-
    2009 Pontiac G8 GT 6.6-"Hairdryers"
    2005 Audi S4 4.2-"Au Naturale"
    2003 Explorer XLT 4.6-"Screwed"
    Jun 24 2015
    UK
    Hi Guys
    I'm seeing the same thing,did you get to the bottom of this?
