Results 1 to 17 of 17
    Jan 12 2009
    Tampa
    Talking How to or DYI DV relocation for 2.0 TFSI
    I've been doing a lot of research and found threads on DV relocation for 1.8t and other 2.0t but nothing specific for our 2.0tfsi. So basically, i was wondering has anyone ever done this for our engines and if so what specifically is needed and how/dyi to do it all. Ive also check for companies to see if there is a kit of some sort but did not see anything and if i did it was other 2.0t VW cars. just little confused about all this, can you guys point or help please, thank you in advanced. all this is new to me as this is my first Audi/ european car.
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    any purpose behind relocation? i think where sits is pretty easy to access from the top if you remove the airbox so i wouldnt worry about the kit.
    Jan 12 2009
    Tampa
    So our DVs don't sit down low in a heated area like the 1.8t? as stated I'm not sure as i have not looked yet, but i thought relocating was to put it in a cooler area to ventilate and have quicker throttle response
    Oct 27 2014
    well honestly i did not know about the cooler area idea. may be someone else can chime in.
    Jun 26 2009
    Bremerton WA
    Its really a non issue on the TSFI. The stock part is reliable and can handle substantial horsepower gains. It sits on the turbo compressor housing and dumps the air from the area just after compressor to just before it. Its also activated by a electrical solenoid vs vacuum pressure. Its response time is very fast.
    VMR 710's, APR software, Eurocode HFC
    Oct 27 2014
    That said is true 100 percent. Only question my stockk Dv would break in to pieces 2 of them so I installed forge any advice on that.
    Jan 12 2009
    Tampa
    i guess it's not if the stock or aftermarket DV can handle the power, but more of the air going in from stick location is good or bad vs a relocation area to a more cooler area in the engine bay and make it better for throttle response.
    Jun 26 2009
    Bremerton WA
    The kits I have seen are from the tight engine compartments of the A3 and GTI. So there may have been some heat issues. The DV is really only active when the throttle body slams shut like between shifts. It opens and loops air back around the compressor. So it would gain some heat from compressing again but its also mixing with cool air coming in, and still going to go thru the intercooler. The 1.8 also had the DV in a different location. The stock design being right at the compressor housing is in the highest pressure zone and also in the place to best control compressor surge. The relocation kits moved the DV from just after the turbo to just before the throttle body. It bleeds off air that has already passed thru the intercooler, back to before the compressor. A vacuum operated DV located that close to the throttle body had advantages of a short vacuum line that likely helped throttle response more than the air being cooled. The money spent just to cool the DV air would be way better spent on a better intercooler.
    May 07 2014
    I thought one of the K04 kits provisions for a DV relocation....
    2010 A4 2.0t quattro 6mt
    Aug 28 2013
    belleville nj
    If anyone wants to see my dv relocation i will take pics for show and tell
    Veteran Member Four Rings auditd0rk's Avatar
    Feb 02 2012
    Colorado Springs
    Quote Originally Posted by zokissima View Post
    Yep. The CTS kit relocates the DV.
    2012 A4 Quattro, Monsoon Grey | CTS K04, HFC | APR K04 v3 Tune | AWE Exhaust | Eurocode FMIC, Alu Kreuz, Sway Bars | Bilstein PSS10 | SPC UCAs | Apikol Rear Diff Mount | 034 Transmission Mount Insert, End-links | StopTech ST-60 BBK | S4 rear brakes | CR-15 brace
    Jan 12 2009
    Tampa
    Quote Originally Posted by vinnys3 View Post
    @vinny , yes please if you can i would appreciate it. also can you give a detail on what you purchased to fully complete our kit.
    Aug 28 2013
    belleville nj
    Will post pics today
    Jan 12 2009
    Tampa
    Anyone else that may want to chime in?
    Jan 12 2009
    Tampa
    bump
    Jan 12 2009
    Tampa
    anyone?
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    If you want a better DV, then get a Go Fast Bits DV, it should offer somewhat improved response. With all the attention these cars get, all the engineers from APR, Unitronic Revo, StasiS, GIAC, AWE, Eurocode, 034 Motorsports, IE Engineering, GFB, CTS Turbo, plus mechanics, other engineers, garage tinkerers & race engineers...if there was a reason to move the DV with a stock turbo, it would have been found by now.
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
