Just bought the car and decided to run it through VAG COM. Still have 4 years of warranty so I am not too worried about these faults. I just wanted to know if anyone had some in sight to what they actually may be.
2013 audi a4 quattro
Mileage: 41280km-25650mi Repair Order:
Chassis Type: FL (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72
77
Mileage: 41280km-25650miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Sporadic communication error 1000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (DET-CPMA) Labels: 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 F HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0007
Revision: ECH09---
Coding: 4A2A0013242600062000
Shop #: WSC 46259 000 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115F 001008
ROD: EV_ECM20TFS0118K5907115F.rod
VCID: 356B3178949AD9898D6-8060
3 Faults Found:
4695 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Freeze Frame:
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Freeze Frame:
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 8K0 927 158 T HW: 0BK 927 156 AL
Component: 0BK 20TFSIUSA H16 1003
Revision: --H16---
Coding: 000002
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002020
ROD: EV_TCMAL551211_AU48.rod
VCID: 47974BB0FE765B19EFA-8012
No fault code found.
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 CJ HW: 8K0 907 379 CJ
Component: ESP8 quattro H09 0100
Revision: -------- Serial number: --------------
Coding: 2D1500
Shop #: WSC 02391 785 00200
VCID: 030F9FA082CEB739732-8056
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 GL HW: 8K0 907 064 FL
Component: BCM2 2.0 H12 0633
Revision: 00002001
Coding: 09814000000000000000
VCID: 000590AC93D8AC216E0-8055
Subsystem 1 - Part No SW: 8K0 959 754 F HW: 8K0 959 754 F
Component: FBSAUDIB8 IDG H71 0083
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8K1 820 043 R HW: 8K1 820 043 R
Component: KLIMA 1 ZONE H02 0121
Revision: A1000000 Serial number: 01210120132843
Coding: 6480208000
VCID: 37773B7086962B999FA-8062
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DF HW: 8K0 907 063 DF
Component: BCM1 1.0 H16 0103
Revision: 06016001 Serial number: 00000540580502
Coding: 26000096863C00C00000480300003D0D0F1C53082209040100 0004004400030100000000000000
VCID: 76E9F674C11C929144C-8023
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 170113 H07 0080
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 AR HW: 8K0 941 531 AR
Component: E1 - LDS H03 0031
Subsystem 3 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Component: AirbagVW-AU10 H45 0610
Serial number: 003KJD91A9NL
Coding: 30454435473030303030554A304C384B3053
Shop #: WSC 39872 001 1048576
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4A917284ED64A671F04-801F
Crash sensor for side airbag; driver side:
Serial number: 6334MSME771312789
Crash sensor for side airbag; front passenger side:
Serial number: 6344MSME743518068
Crash sensor for side airbag; rear; driver side:
Serial number: 6352QSME2F2D047EY
Crash sensor for side airbag; rear; passenger side:
Serial number: 6362QSME132833727
Crash sensor for front airbag; driver side:
Serial number: 63732SME022B3544U
Crash sensor for front airbag; front passenger side:
Serial number: 63832SME01282166Q
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 L HW: 8K0 953 568 L
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372MA70029C
Coding: 000016
VCID: 438F5FA0C24E7739332-8016
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 901 C HW: 8K0 920 901 C
Component: KOMBIINSTR. H09 0556
Revision: 00400000 Serial number: UVB54FE1E
Coding: 8B86090002010008020000
VCID: 2B5F17004ADE9F79EB2-807E
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 L HW: 8R0 907 468 A
Component: GW-BEM 5CAN H11 0055
Revision: 1V070026 Serial number: 2641V131148443
Coding: 80C303FF00
VCID: 4895488CFB685461E60-801D
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
2 Faults Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 7
Reset counter: 218
Mileage: 40527 km
Time Indication: 0
Date: 2015.01.21
Time: 03:51:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 11.80 V
Count: 7
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 218
Mileage: 40544 km
Time Indication: 0
Date: 2015.02.18
Time: 13:58:09
Freeze Frame:
Bin. Bits: 10000
Voltage: 11.70 V
Count: 7
Bin. Bits: 10000
Time: 4.90 s
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020302
VCID: 39733D48B0823DE969E-806C
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C03204000410001
VCID: 56A996F421DCF29164C-8003
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0300316536
Coding: 0106023A00FA000480B0013200000000
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 2 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS050 H08 0043
2 Faults Found:
03128 - Switch 1 for Sunroof
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 218
Mileage: 40544 km
Time Indication: 0
Date: 2015.02.18
Time: 11:34:00
01514 - Regulator for Roof
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 218
Mileage: 40544 km
Time Indication: 0
Date: 2015.02.18
Time: 11:34:00
Address 47: Sound System (J525) Labels: None
Part No SW: 8R1 035 223 A HW: 8R1 035 223
Component: DSP STD H08 0230
Revision: 26S00000
Coding: 0203010102
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
VCID: 55AB91F83CDAF9896D6-8000
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 20000000202831
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_AU48.rod
VCID: 3875384C838824E1960-806D
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8R1 035 186 Q HW: 8R1 035 186 Q
Component: Con3 Sirius H09 0471
Revision: 00000002 Serial number: AUZ5Z6M1841418
Coding: 04020002010187000158070800
Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0304
Coding: 010C03204000210001
VCID: 59B39DC850C2DDE949E-800C
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H07 0304
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 336 F HW: 8T0 862 336 E
Component: FSE_256x BT H45 0660
Revision: 00000000 Serial number: 00000005297307
Coding: 0010370
VCID: 3E792E5469AC1AD15CC-806B
End-------------------------(Elapsed Time: 03:57)--------------------------
Address 09:8K0 907 063 DF channel 3 adapted from 26 to 100
