Results 1 to 8 of 8
    Veteran Member Three Rings BMWBig6's Avatar
    May 20 2008
    Georgia
    Question Advanced Key "Comfort Access" (Unlock with Key Fob in Pocket) Stopped Working
    The archives had 3 threads that mentioned possible sensor failures but is this something only the dealer can diagnose? Both of my advanced keys can start the car (with key in my pocket), and the lock/unlock remote buttons work fine, and even the trunk release button too. But neither key will let me lock the car by pressing the little square button on the door handle, or unlock it by grasping the door handle. I already tried all 4 doors, put the key as close as possible to the car (even tried laying it on the roof or by the windshield in case the sensor is in the middle of the car), and replaced the batteries in my key fob with no change or improvement.
    I did notice the following passage in the owner's manual:
    If the diode on the driver's window sill lights up for about 30 seconds when the vehicle is locked, the central locking system or anti-theft alarm* is not working properly. Please have the
    My car's red LED on the driver door does exactly this! Illuminates for exactly 30 seconds every time I lock the car (from the remote button on the fob since the door handle button isn't working).
    Another clue is that I've not driven the car that often this winter, in case the battery or "power saving mode" may be relevant. The car may sit for a week or so before I drive it again.
    2020 F-Pace SVR / 2016 GLE350 4MATIC
    Favorite Former Rides: 2015 Boxster GTS / 19 E450 Wagon / 2015 X1 M Sport / 11 F-150 Limited / 09 A4 Avant / 08 TT / 03 SVT Lightning / 01 SVT Lightning / 93 740iL / 90 535i / 86 944 Turbo / 83 944
    Veteran Member Four Rings oascom's Avatar
    Jan 08 2013
    New Jersey
    Sorry to off topic a little but I'm wondering why my non advanced car got this little square on the handle...
    Hope u can get it fixed :)
    APR, Eurocode, AWE, P3, aFe , CTS, Spulen, H&R, 034Motorsport, STaSIS
    Veteran Member Four Rings boomtime's Avatar
    Apr 22 2013
    Audi, BMW, Ford
    Rocky Mountains
    Probably the nearfield sensor. Usually in the door itself.
    This is something I would shell out for with the dealer unless you have an extended warranty.
    The eventual supremacy of reason.
    CPMB K04+e85
    Twin Turbo 391
    E36 Drift Queen
    Senior Member Two Rings helldriver's Avatar
    Oct 25 2014
    Cincinnati, Ohio
    Quote Originally Posted by oascom View Post
    09 here and I got the square on all four handles?
    Hope it works out, cheers...
    2008 Audi RS4
    Jan 08 2013
    New Jersey
    Quote Originally Posted by helldriver View Post
    Yeah mine is 09 too
    Mar 26 2012
    Charlotte, NC
    Scan your car, your sensors might be broken. Two of mine failed and the dealer replaced all 4 with the updated ones.
    May 20 2008
    Georgia
    Quote Originally Posted by boomtime View Post
    Quote Originally Posted by SDF1 View Post
    Thanks for the suggestions. After obtaining VCDS, I found the following DTC error code. I guess I found my culprit?
    Address 05: Acc/Start Auth. (J393)
    1 Fault Found:
    03285 - Sensor for Contact with Door Handle; Front Left
    011 - Open Circuit
    I also found these, but I'm not sure if related:
    Address 6D: Trunk Elect. (J605)
    2 Faults Found:
    00317 - Rear Lid Control Module (J605)
    008 - Implausible Signal - Intermittent
    16347 - Control Module - EEPROM Error
    014 - Defective
    Mar 26 2012
    Charlotte, NC
    Check your PM
    4G8927753 Door handle touch sensor – from MY09 A4, A5, A5 Cabriolet, Q5
    Also paste your entire VCDs log. I don't like that last EEPROM error.
