    Aug 23 2011
    Erie
    how many cyl heads have been cracked
    I have cracked one AEB cyl head and maybe another one I will find out when I take it off my car.
    Who else has cracked them? And what was the cyl head?
    EDIT...
    USRR NAME AND CYL HEAD CODE;
    ME,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,, AEB
    onceover,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,, AMB
    ColinBuger00,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, AMB
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    you are the only one. CONGRATS! ! !
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Aug 23 2011
    Erie
    Quote Originally Posted by GrapeBandit View Post
    Lol... im not the only one. There have been a few AMB heads that have cracked.
    Feb 27 2011
    Winnipeg
    My amb cracked up the #1 spark plug hole when I pulled it to change the head gasket. I probably could have got away with re using it but I found a used awm head for cheap.
    Jun 30 2008
    Erie, Pennsylvania
    It is my pet theory that the AMB heads crack more often because of the silly "mapped cooling system" (ie: electronic manipulation of the thermostat). Specifically the AMB runs 10-15C hotter than the earlier engines during cruise, and upon acceleration it will dump the temp as quickly as possible. I believe running it hotter, and specifically the rapid temperature fluctuations commanded by software, are the cause for higher head gasket and cylinder head failure rates in the B6 1.8T as compared to B5 1.8T.
    But that's just my pet theory. And I'm not a even mechanic, so you can take that for what it's worth. Which is nothing. ;)
