Results 1 to 40 of 48
    Veteran Member Three Rings Audi Advocate's Avatar
    Mar 26 2005
    2012 B8 S4, 2012 A3 Wagon
    B8 S4 Coilover recommendations - looking for specific advice based on use - not drop
    I searched relentlessly in here and I can find a ton of recos on coilovers - all brands - based on drop/clearance but nothing really on ride performance.
    I have:
    - 2012 B8 S4
    - Alu Kreuz
    - Rear H&R sway
    - No "true" ADS - only throttle, steering and rear diff settings unde "Dynamic/Comfort/Individual and Auto" .
    I track 2-3 times a year, corner aggressively and live in Toronto - home of the original 4" deep pot-hole.
    I am looking for (non-cheap end) coilover set-up with a compliant ride that can take to the track/aggressive driving without sacrificing as a daily driver. Ride height is not as critical as performance.
    Appreciated!
    Current #1 2012 S4 3.0T DSG Technik with Unitronic Stage 1+, Milltek res., KW V2 coilovers, StopTech BBK, Alu Kreuz, H&R Rear Sway, BBS CH-R's, Michelin PS4S, Disabled wink, De-badged, ZIZA LED's, 30% tint and fancy aluminum pedals - Current #2: Wife driven 2012 A3 2.0T Progresiv- stock
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    I have been eyeing up the H&R RSS coils they sound like a match for your needs
    http://www.awe-tuning.com/h-r-coilov...19-1-coilovers
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    I'm in the same boat as you and thinking it's just better off to keep stock everything except throw on some H&R springs... I've been warned about the pot-hole love and how uncomfortable my ride would be with a set of PSS10's for example living in the north east. What are your thoughts?
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    May 17 2012
    Houston, TX
    I think your search will lead you to Bilstein PSS10 or H&R RSS. I have been looking as well and my main gripe with the RSS is the unlabeled adjustment knob. Either you can put your own marks on the knob or remember the adjustment but you'll need to start at one end or the other and then begin adjustments from there. Any coilover, regardless of cost, should have labeled adjustment knobs if it want to be called adjustable.
    Mar 04 2013
    Agoura Hills, CA
    I have the Bilstein B16 Electronic Damping Controller (EDC) with the IRC Wifi Ride Control option on my 2011 S4. I also have the following: Eurocode front and rear sway bars with adjustable end links, Alu Kreuz chassis brace, Stoptech ST60 BBK in front, Endless MX72 brake pads front and rear, stainless braided brake lines front and rear, Castrol SRF Synthetic brake fluid, Borla exhaust, Injen cold air intake and i run Neuspeed RS52 18 by 9 wheels with 265/35/18 tires for the track (HRE 567R 19 by 9 1/2 wheels with 275/35/19 tires for the street). Everything works very well together. On the street the car runs a lot smoother than stock. On the track it is much stiffer, corners flatter and has much less body roll. You simply dial up the suspension with a button on the dash. To fine tune the suspension you use the Iphone to set everything up to your liking. Make sure to set up the ride height and alignment properly when you finish the setup and before you track. Just keep in mind you will start with one little thing and before you know it you will spend well over $20K. Be careful my friend and drive carefully!
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by Usa View Post
    Springs alone will be the more uncomfy option. The PSS10 can ride as nice as you like. Even H&R streets ride better than lowering springs alone.
    Quote Originally Posted by AKPS4 View Post
    Yep. I'm ordering the PSS10 very soon. The standard ones.
    Mar 04 2013
    Agoura Hills, CA
    The shocks and springs that I mentioned above are an electronically adjustable set of the PSS10's. Great suspension with the convenience of pushing a button to adjust the firmness.
    Aug 16 2014
    Denver
    Whoa - not a good idea if your goal is anything other than just lowering for appearance. (I've done it so I speak from experience).
    Springs alone for better performance or ride quality are not good. Search for a recent thread "I don't like my car at high speed" (the name should give you an idea what you're in for with just lowering springs)
    I've been looking at the pss10s as well.
    Dec 23 2013
    B8 S4
    Quote Originally Posted by myrison View Post
    Yeah I read that, which is why I'd do shocks as well... I want to do the PSS10s I've just been advised against for the north east terrain.
    Veteran Member Three Rings OldSport//'s Avatar
    Jun 17 2014
    Texas
    I have the same goals and am also thinking PSS10's. Seems like we have a theme going in this thread.
    *Previous* 2014 DSG S4 - Glacier White | Black Nappa | B&O | MMI | Carbon Atlas | Peelers
    *Previous* 2014 6MT S4 - Brilliant Black | Black Alcantara | Black Optic | Sport Diff | B&O | MMI | Carbon Atlas | Side Assist | Stoptech 380mm Trophy BBK | TSW Nurbs | EuroCode Sways and End Links | 034 Transmission Mount | 034 Rear Diff Mount | Spulen Diff Mount | CR-15 Strut Tower Brace | SRP Racing Pedals
    Veteran Member Four Rings PsYkHoTiK's Avatar
    Aug 23 2010
    Redmond, WA
    I have the RSS+ on the RS5. Rides harder than the stock RS5's suspension for sure but corners really well. It has a linear spring though and can ride rather harshly in the city (I don't really mind - especially since I'm alone in the car most of the time). I do get the slight bobble head effect in "rough" downtown roads. But, I also track it ~6-8 times a year and daily drive it on a short commute.
    Since you only do 2-3 track days a year, I would perhaps look at the PSS10 and other street performance coilovers rather than a more track oriented/club sport set up. On a street car, it's compromises that you can live with. If possible, ask around and see if you can ride shotgun with someone else that has coilovers installed in their car (if it's the same platform - B8/B8.5, it should feel the same).
    Current: 2022 Audi RS6 | Ultra Blue | 034 Lowering Links | 034 Resonator Delete
    Old: 2017 Chevrolet Corvette Z06 (Z07) | Blade Silver
    Older: 2013 Audi RS5 | Sepang Blue | Eurocode Alu Kreuz | 034 Transmission & Rear Diff Mount | Apikol Diff Mount | Girodisc 380mm Rotors | H&R RSS+ | SPC Upper Control Arms | H&R sways | AWE Track Extreme exhaust
    Olderer: 2011 Audi B8 S4 | Ice Silver | DSG | Sport Diff | APR 93 stage II+ V2
    Oct 14 2012
    Empty...for now...
    SE PA
    Do not go for H&R Street Performance coilovers if comfort is a goal. Mine are downright harsh in the cold temperatures we have been experiencing, so I imagine you would have similar results in Canada.
    SOLD 2015 Daytona Gray S4
    Feb 25 2013
    MI
    Quote Originally Posted by 1AkitaOne1 View Post
    Not to derail, but what are your thoughts on the Neuspeed RS52 wheels (I'm assuming 18x9 et 40)? I'm considering throwing some A048 tires of the same size 265/35R18 but might just go R888 at 255/35R18. I have a 355mm ST60 in front, so I'm assuming you don't need spacers? I'm slightly dropped on H&R OE springs, and will probably dial in about 2.1 deg of camber up front. Really don't want any rubbing issues, which I believe will only happen up front with this fitment.
    The other wheel I'm considering is a TSW nurburgring at 18x9.5 et 40, but then I pretty much have to run the 265 tire and will have an extra 6mm of wheel.
    Thanks for the info!
    Mar 04 2013
    Agoura Hills, CA
    I like the RS52 wheels, not bad for the money. Relatively light and strong. They are around 20 pounds. I would have preferred my 18 by 9 Enkei RPF1 wheels. They had an ET of 37, fit the stock brakes and had no rubbing issues no matter how low I go. The best thing of those wheels is they only weigh 17 pounds! On the track you can run either the 255/35/18 or the 365/35/18 Hankook RS3 tires on these wheels with no problems. I would NEVER run a spacer on my car and would only purchase wheels that fit as intended. By the way if you know anyone who is interested (and has the stock B8 S4 brakes), the Enkei wheels are for sale.
    Feb 25 2013
    MI
    Exactly what I was looking for, was about to have some PF01's redrilled for me but found out they don't clear the ST60 calipers. Was pretty bummed about that. I ran 3mm spacers on my forgestars when I was first doing track events, and one time the bolts came loose and I thought something was seriously wrong. No more spacers for me on the track.
    The TSW wheels are also very light (around 18-19 lbs I believe), but the 9.5" width is a little more than I want with beefier track tires. But I'm crossing my fingers that enough neg camber will eliminate the chance of rubbing. But the price on those nuespeed wheels from moddedeuros is 950 shipped, which is pretty hard to beat.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    If you want or care about adjustable dampening get the aft mention Bilstein PSS10, if you want comfort/non adjustable dampening get the H&R Streets, the difference is about $1000.
    Stage 1 more than you RS3
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by SteveYem View Post
    Pretty much any shock is going to ride harder in colder temps until the fluid gets moving around. Tires get harder too, so do suspension bushings and the like, just something you have to accept unfortunately.
    That being said H&R streets are a nice middle of the road coilover.
    Jason
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by o1turbo30v View Post
    FWIW, adding to my previous post: the H&R Street Performance coilovers on my 2015 S4 get so stiff in cold temperatures that the car loses traction and skips out when hitting a bump or rut when cornering. There is a spot on the road I take home every day from work, about 3 minutes into my drive, where I have experienced this phenomenon consistently in the cold temperatures we have been experiencing during the past month here in southeast PA. I understand that you can't fool mother nature....temps are sub-freezing, hydraulic fluid viscosity goes up, resulting in overly stiff shocks. What I'm wondering is if the more expensive adjustable shocks (Bilstein et al.) handle this any better. I suppose one could adjust to a lower stiffness setting during the cold months to offset the increase cold-temp viscosity of the fluid.
    But I will say that after extended drives in cold temperatures, like 1+ hours, the ride becomes much more comfortable. I guess after enough oscillations there is sufficient heat built up in the dampers, even in cold ambient temperature, to get the fluid viscosity back down to nominal levels and provide the advertised (implied?) level of comfort.
    Oct 14 2012
    Empty...for now...
    SE PA
    Jason
    Good point, I wasn't even thinking about tires and bushings, but those would also contribute to the sensation I am noticing lately. I'm really looking forward to warmer temps within the next few weeks so I Can get back to a reasonable level of comfort!
    Oct 02 2006
    Wadsworth,OH
    Yep! Trust me I am too! My B6 A4 on coils gets pretty stiff in single digit temps and below. I do mostly highway driving so it's not too terrible but when I'm on bumpy side roads it's not fun haha.
    Jason
    Jul 16 2012
    Mid-Atlantic
    Can you have near stock ride height for the PSS10s?
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    Go vogtlands they really good.
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Some broken BMWs
    Branford, CT
    Quote Originally Posted by B44 View Post
    I'm a huge personal fan of Vogtlands myself, had them on prior B5 S4's and loved them. The H&R premium were very nice too.
    My Vote go for Bilstein PSS10 or KW V3 or DDC in the B8 if you pan to daily/track the car. But my opinion is rather subjective.
    May 17 2012
    Houston, TX
    Seems like plenty of interest in PSS10's. I wonder if a group buy can be setup.
    Dec 27 2014
    I'm just posting so I can follow this. I don't want to lose comfort as well.
    However, I will note that Bilstein PSS systems are typically looked at as one of the best options on MANY platforms for their compliance in daily driver use. I have also been told that KW V3s are also very good when not set stiff but I will need to follow up with the race shop that I talk to about that.
    Veteran Member Four Rings chillindrdude's Avatar
    Jul 05 2013
    northern virginia
    I have Bilstein PSS10s. They strike a nice balance between DD compliance and body roll control on the track.
    A very worthwhile upgrade for the B8S4
    Veteran Member Three Rings tgsweat's Avatar
    Nov 05 2011
    maryland
    How many of you get the binding issue with the Bilsteins? That's what keeping them off my list although I want them so bad.
    Mar 26 2005
    Jason
    Thanks Jason - good to know - I appreciate the experience from a North Easter's pov as well. - Cheers!
    Veteran Member Four Rings GeoJoe's Avatar
    Jun 08 2012
    Q7, Q5, 2016 Porsche GT4, Subaru Sambar, Honda Acty Van and a 2018 Tundra Loooooooong bed
    ATL GA
    Subbed
    Veteran Member Three Rings Maitre Absolut's Avatar
    Aug 06 2009
    RS6, X3 30e
    Montreal/Toronto
    if you are running the car year round I strongly suggest full stainless steel which eliminates H&R for the B8
    I researched before getting the KW HAS kit, it seems there is no setup that is without issues even in the high end PSS10 and KW V3.
    2023 RS6 | GW / ER | CTS res delete | Ghost links | H&R 10/12
    2023 X3 30e
    2019 SQ5
    2018 M3 CS
    2017 Macan GTS
    2014 S4
    2009 A3 3.2q
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Ohlin SL's
    loved mine!
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Sep 28 2010
    NW NC / DE
    PM me. I'll take good care
    Mar 26 2005
    What level KW is this?
    Quote Originally Posted by Maitre Absolut View Post
    We are enduring the same harsh climate - curious of you are V1 or V2?
    I had heard about having to over-oil some kits to stop rusting - KW is stainless ?
    Thanks !
    Veteran Member Three Rings brainpan's Avatar
    Apr 11 2010
    sk8 banana
    ontario
    Good to know about the H&R, they were on my list, I was under the impression they were full stainless
    Bryan
    Aug 06 2009
    RS6, X3 30e
    Montreal/Toronto
    Quote Originally Posted by Audi Advocate View Post
    Thanks !
    Yes KW is stainless. ST is the galvanized steel version.
    Quote Originally Posted by brainpan View Post
    They make a SS kit just not for the S4
    2023 X3 30e
    2019 SQ5
    2018 M3 CS
    2017 Macan GTS
    2014 S4
    2009 A3 3.2q
    Aug 15 2014
    kwv3 or clubsport. I ran the kwv3 on my m3 and they ride amazing.
    Aug 16 2014
    Denver
    Quote Originally Posted by chillindrdude View Post
    I just got my B16 / PSS10 put in on my '14 S4 3 days ago. I also put in the iRC module that allows the suspension to be adjusted via iPhone/Android. Man it's a sweet setup.
    I upgraded from H&R OE sport springs, which I was very dissatisfied with (floaty is the best description I've read, and it's accurate).
    I realize I haven't had them long enough to post a meaningful review, but I can confidently say that these give a very nice looking drop with ZERO sacrifice in ride quality in comfort mode, and an awesome experience in sport mode.
    I have no experience with other coilovers so I can't compare. I can just say these are a great investment. Good luck with your choice.
    Mar 26 2005
    Wow - nice mods - am envious you are in Cali - here in the Northeast I must go KW it looks like since they are stainless and even at that will likely have to take care of them.
    Seems like most interest is in PSS10's - are they less expensive than the KW?'s I have V2's priced out at CDN $2400 installed.
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    KW is offering a rebate on coil this month.
    Aug 16 2014
    Denver
    About the same installed on the Bilstein if you don't get the iRC. If you do, another 600-800
