Results 1 to 10 of 10
    Mar 05 2013
    18 TTRS, 09 Audi TTS, S5 Stage2, TT Mk1 Roadster
    Lakeland, FL
    overheating need advice
    3.0Tmotor
    ok, got a call from the wife. I won't be able to look at the car until tomorrow.
    She got a high coolant temp. Warning turn engine off message.
    Temp gage was far right on high.
    She pulled over. Opened hood, coolant level in the overflow tank was correct just below max.
    Engine compartment did not feel hot and no coolant was leaking.
    Ten minutes later she started the car. The gage was at half. She turned the heater on full. She could drive about 5 miles before the gage it went up to 3/4. She pulled over opened the hood no coolant leaking and she could touch the cylinder head it wasn't too hot. She waited another ten minutes later the was able to go another 5 miles to get home before the gage climbed to 3/4.
    I live in Florida it 80 Degs.
    My thoughts:
    1. If the car was overheating, it would not have cooled off to 180deg, half way on the gage in 10 minutes.
    2. If the car was overheating, she would have felt a lot of heat when lifting the hood.
    3. If the thermostat was stuck would she be getting hot air out of the heater core in the car?
    4. My buddy is pointing at the temperature sensor, I would think if the sensor was bad it woulding be climbing consistently to hot it would be more irrattic.
    5. My buddy says when I get home to read the temp sensor output and the radiator outlet temp. Compare them, if the radiator is staying at 190degs but the temp sensor is hot then it's the sensor.
    Any additional troubleshooting or suggestions would be appreciated.
    Thanks
    Ed
    IE Twin Scroll EFR 6758 Stage 3+, AquaMist WMI, Wagner Intercooler, 42DD 3" Cat_Back, APR HPFP, UM DSG stage 3, Race Hadlex, 034 Catch Can, MSS springs, Nuespeed ARB front rear, 034 Rear ARB links, 034 Rear Trailing arm bushings, 034 dogbone and mtrmts, Tyrosports deadbolt, OZ Racing Wheels, Michelin PS3, P3, Schroth Quick Fit Pro harness, Stoptech Rotors and SS Brakelines, Tyrolsport Caliper Guides and Hawk Racing pads.
    Sep 21 2014
    Baltimore Maryland
    Thermostat is stuck in the closed position. Engine isn't hot, the water is.
    2014 Audi A6 3.0t
    2015 Audi S4 DSG
    Veteran Member Four Rings skiracerblah's Avatar
    Jan 03 2011
    Evo X MR : 290whp, 313 lbs/torque @ 24psi; Evo IX : 383whp, 383 lbs/torque @ 28psi E85
    San Fernando Valley, CA
    Thermostat is stuck. I had the same problem a few weeks ago and their is a TSB or recall going on
    Sorry for newbie questions, this is my 1st Audi
    Current: Phantom Black '2011 S4 S-Tronic Premium Plus, Sports Rear Diff, JL Audio subwoofer upgrade, Milltek Resonated Exhaust
    Old cars:
    Evo X MR-Touring stock, but tuned by RRE: 290whp, 313 lbs/torque @ 24psi 91 octane
    Evo IX tuned by RRE: 383whp, 383 lbs/torque @ 28psi E85 ethanol fuel
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Wow, judging from your signature, that's a full blown race car. That's cool that your wife can drive it on the street. Sucks the POS T-stat is an Achilles Heel for everyone.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Apr 17 2004
    Socal
    Quote Originally Posted by sacandagaD View Post
    That signature is not the S4. Sounds like a TTRS
    Veteran Member Three Rings S4Phantom's Avatar
    Jun 10 2012
    Thermostat has failed. Get it replaced.
    2011 Phantom Black S4 Prestige Titanium Pkg., Sport Diff., Alu Kreuz, Milltek Non-resonated exhaust with oval tips, AWE Carbon Fiber intake, Stage 1 GIAC, Black powder coated Titanium Pkg wheels
    Veteran Member Three Rings tanklee's Avatar
    Dec 31 2004
    NJ / Miami
    thermostat.
    2000 B5 A4 Quattro
    2000 B5 S4 6spd Stage 3
    2014 B8.5 S4 DSG
    2005 B6 A4 Quattro USP
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by paul View Post
    Or a Golf R.
    Oh and OP, you misspelled Haldex in your sig.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    If the T stat was stuck CLOSED, you would not get heat out of the heater. This is what generally happens with these cars. Common problem. . Might want to replace the PVC valve while you have the SC off. It can eventually fail causing an increased oil consumption. Also common problem.
    Mar 05 2013
    Lakeland, FL
    Thanks for all the help!!!!
    yes my sig is my TTS, the car is actually any 2011 S5 Cab. With an AWE carbon in take Borla exhaust, RS grill, HR Struts and swaybars and Niche wheels. and its going for a 2+ tune in a month.
    I posted here becasue there seems to be more people in the S4 forum with knowledge of that motor.
