Results 1 to 21 of 21
Thread: Engine cover
    Nov 17 2014
    Spokane
    Engine cover
    I have been searching all day for it but I'm looking for the cover that goes over the abs and windshield fluid tank and the hydraulic fluid tank that pretty much goes over the whole right of the engine... I'm in desperate need to buy one asap
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    This one? Part number is 3B0 119 487C.
    Edit: Damn, Ray beat me to it. ;)
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    dang you two beat me :l
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Veteran Member Four Rings ray4624's Avatar
    Nov 27 2010
    mass
    IBS coming in clutch
    May 18 2010
    IBS rolling deep.
    01 S4 2.7T: Stock
    Dec 05 2007
    I was here
    Modifications necessary for fitment.
    Oct 09 2012
    IBS is the bestest.
    Quote Originally Posted by BaseDrifter View Post
    In news more relevant to my own car, I'm very close to saying that "stage 1" of my engine bay is complete. One of the last pieces of the puzzle was getting a euro Passat driver side engine cover (part number 3B0 119 487C.)
    The cover is not a drop in piece though. It took a bit of fitting and problem solving to get it to sit in place properly. I'm still fussing with it, but it's very close.
    The first thing that needs to be trimmed is where the cover contacts the throttle body.
    I cut out the corner with a jig saw, hand filed it smooth, and rounded the corner off.
    A notch has to be cut near the upper radiator hose, and I was also getting some contact near the windshield washer tank. I cut a 2nd half moon near the windshield washer tank as well as shaved the lower circle of the washer cap down flat on the side. With the cover sitting properly at the bottom, it leaves a 3/4" gap near the firewall. This is not the end of the world, it's not very noticeable unless you're looking for it, but I'll probably try to fit a piece of weather stripping at the upper edge to seal it off.
    The last problem was finding a way to make it sit flat. The middle of the cover hits the lower right corner of the ABS pump and acts as a pivot point. I didn't want to drill into the cover if I could avoid it, nor did I want to modify my car in some way that was not reversible. I wanted to be able to remove the cover easily as well. What I came up with was using two bar magnets wrapped in electrical tape and topped with a piece of velcro. The magnets are placed next to the hood shock and hold the top right corner of the cover down to the proper height so it's flush with the hood's weather stripping.
    The end result.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    They dropped the price on that cover. I had been eyeing it when it was $89.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Oct 09 2012
    Quote Originally Posted by ray4624 View Post
    IBS rolling deep.
    Quote Originally Posted by King_Life View Post
    IBS is the bestest.
    Gota love irritable bowel syndrome.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    May 18 2010
    In addition to the fitting I talked about in my thread (quoted above), I also had to make a little relief cut for the throttle cable on the TB. Shouldn't be necessary for DBW cars though.
    01 S4 2.7T: Stock
    Oct 30 2009
    Miami, FL
    Weren't these available on NA Passats too? ETKA says Euro only but I've seen them on junkyard cars a few times. Or is that a slightly different cover or something?
    2018 S5 Coupe - stock for now
    May 18 2010
    I've only ever heard of them being on euro passats, seen plenty of passats at the junkyards but never with that cover. Then again I don't think I've ever seen an NA passat either.
    01 S4 2.7T: Stock
    Oct 30 2009
    Miami, FL
    NA as in North American, not naturally aspirated. I've even seen one of those on a '01 A4, but that was probably installed later at some point. Sucks that every single one I've seen was broken in some way.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    that cover is nice, but you still need to paint your washer reservoir and coolant tank black to "hide" everything, all its really covering is open space, and the power steering reservoir. too bad it doesnt cover all of that and just leave holes for the circular fill caps, that would be hot
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Veteran Member Three Rings ama's Avatar
    Oct 02 2013
    World
    Does this fit 2.7?
    May 17 2014
    Raleigh, NC
    I wanted to try a B7 cover but gave in for the tried and tested euro passat cover. My TB was already rotated so I didnt have to trim anything (iirc). No velcro, although not a bad idea, I dont need any extra encouragement for it to stay in place.
    by rodgertherabit ii, on Flickr
    Nov 17 2014
    Spokane
    Hell yeah thank you, jeez that's so sexy
    May 17 2014
    Raleigh, NC
    Kudos! Thats when It was wrapped lol. Kinda miss having the blue again.
    Dec 13 2010
    FL
    Quote Originally Posted by rodgertherabit View Post
    now paint your windshield washer and coolant reservoirs black and it will be money!
    Orange County, CA
    Looks good!
    B5 Parts For Sale
