Results 1 to 10 of 10
    Jul 18 2013
    Brandon, MS
    For those of you with powder coated intake manifolds....
    I've taken my valve covers off and separated the upper intake manifold from the lower, to have them coated. The company is separating the upper in two. What have you all used to properly seal the two halves together correctly?
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    Remove old gasket and apply RTV sealant seems to be the course of action.
    source:
    http://www.audizine.com/forum/showth...ntake-manifold
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Jul 18 2013
    Brandon, MS
    Just to clarify, I do mean once the top is already off of the bottom. They have asked that the top half be separated again. I wasn't aware that this was necessary but I wanted to make sure before I said yes or no.
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    permatex ultra black is what i used... no problems
    PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
    2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
    Veteran Member Three Rings breal's Avatar
    Nov 15 2010
    IN
    It shouldn't need to, and can it even really without being damaged?
    TGM C7 S6
    DG B6 S4
    2017 Colorado Z71 Duramax
    2006 Triumph Daytona 675
    Jul 18 2013
    Brandon, MS
    He called me an hour ago and said he was finished.. I'll post pictures tomorrow of the results.. before and after and whatnot
    Jul 18 2013
    Brandon, MS
    So the guy was just being overly cautious and the screws were in fact the casting screws left by Audi.
    But here's the finished product; minus the MAF hose for anyone wanting to point that out.
    Veteran Member Three Rings M3PowerPlay's Avatar
    Dec 31 2013
    Supercharged E46 BMW M3
    Powell, Ohio
    Looks really good! My car is the same color as your's and I recently chose to have my manifold coated a similar color.
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Nice. My engine bay will look almost identical within a few weeks.
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Jul 18 2013
    Brandon, MS
    Thanks guys.. I love it
    While the intake is off you may want to change any sensor behind the engine that would give you trouble.. I did the coolant temp sensor and it was a pain even with the intake off.
