Results 1 to 15 of 15
Thread: Coming Soon...
    Sep 17 2005
    Fremont, California
    Coming Soon...
    I know a lot of folks have been wanting to upgrade their rear differential carrier / rear crossmember bushings for a while now, and I'm pleased to say that we'll soon be releasing another first for the B7 Audi RS4 platform!
    I've had these on my car for quite a while now, and they take up a significant amount of slop that remains even after you install something like the Apikol differential mount up front. Our upcoming 034Motorsport B7 Audi RS4 Performance Rear Differential Mount Inserts are designed to be very simple to install, and we'll be providing full installation instructions at release.
    Stay tuned for more info, and a forum-exclusive introductory special offer!
    Jan 15 2010
    Santa Barbara, CA
    Any increase in NVH?
    Veteran Member Three Rings OscarMeyer's Avatar
    Oct 01 2010
    VW/AUDI Only
    Burnaby
    I'll be snagging these along with the psi coils and a few other of your suspension/drivetrain related pieces shortly, Any idea of the final release date?
    Keep up the good work gents!
    07 RS4 - Projekt: Pandora
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    Just installed mine, review coming tomorrow.
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    Apr 03 2012
    Raleigh, NC
    Quote Originally Posted by BenSti View Post
    ben -- i am thinking of stiffing my car up a bit, i currently bought the ecs rear diff mount...what other items should i get? For example, I was thinking of getting the 034 trans mount...should i get track or street density? i want it tight and not too concerned about vibration...you think track is too much for DD?
    thanks in advance.
    Nov 03 2010
    Cupertino, CA
    Quote Originally Posted by swesna View Post
    thanks in advance.
    Here's what I would do:
    034 Engine Mounts (Track Type, 10mm Studs)
    034 Density Torque Mount
    034 Track Density Transmission Mount
    034 Differential Carrier Inserts
    PowerFlex Rear Diff Bushing Insert (Purple)
    Apr 03 2012
    Raleigh, NC
    Thanks Ben...will be ordering them this week. Plus need to get some oil and an oil filter. Looking to work on the car a bit once the weather gets nicer which should be soon
    Veteran Member Three Rings MidwestB6's Avatar
    Aug 01 2013
    1970 Ford Maverick
    Iowa City
    Quote Originally Posted by Keaton@JHM View Post
    We've tried out ALL of the combinations on our shop B7-RS4 and I've got some feedback on the setups. On the transmission mount, we'd go with 034Motorsport Street Density. We've tried Track Density and although it locks the transmission down well, it transmits a NOTICEABLE amount of vibration through the cabin and into the seat. The Street Density Mount is PLENTY capable of locking down the transmission on the B7-RS4 (it did for us on all of our record setting, all-motor runs in addition to our testing with our Supercharger Kit ). For the Rear Differential Mount, you can get away with upgrading to the Red/Stiff bushing without sacrificing much for cabin comfort. It will give you a small increase in vibration but it's not that noticeable and for the upgrade, I think it's worth it.
    Track transmission mount might be a bit much. I have the street mount, I think even that adds quiet a bit of vibration, very solid though. I don't notice unless my hand is on the shifter, which it shouldn't be anyways. 034's motorsport engine mounts are a must, though.
    2004 Light Silver 6MT S4
    Nov 03 2010
    Cupertino, CA
    Quote Originally Posted by MidwestB6 View Post
    Just FYI, that is not what I am running currently, but has been my ideal setup (in terms of most streetable parts. I am currently running the following:
    Custom Torque Mount (Much stiffer than density line)
    034 Track Aluminum Transmission Mount
    034 Aluminum Subframe Bushings F/R
    PowerFlex Rear Diff Bushing Insert (Black)
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by forbiddenbeat View Post
    I didn't notice any when I installed them on my car, which just has some Street Density Engine/Transmission Mounts and an upgraded snub mount. That being said, if you have something more similar to Ben's track setup (solid aluminum subframe mounts, motorsport engine/transmission mounts) you will likely see some increase in diff noise.
    Quote Originally Posted by OscarMeyer View Post
    We should be announcing an Introductory Group Buy sometime next week!
    Jul 07 2014
    Oakland, CA
    Looking fwd to the group buy on the inserts and related pieced that Ben mentioned. Thanks Ben and 034!
    2016 Porsche 911 Targa 4 GTS - Carmine Red
    2015 VW MK7 Golf R - Oryx White
    2007 Audi RS4 - Phantom Black SOLD
    Established Member Two Rings mpowertech's Avatar
    Mar 17 2013
    Baltimore
    Quote Originally Posted by calijax View Post
    X2
    Sub'd
    2017 Toyota Tacoma
    2008 RS4 Phantom black, Sold
    Dec 07 2009
    East Coast
    It already got started in B6 A4 section: Coming-Soon
    Forget the B8, keep the V8!
    Oct 01 2010
    VW/AUDI Only
    Burnaby
    Quote Originally Posted by 034Motorsport View Post
    Awesome I'll keep my eyes peeled!
    Sep 17 2005
    Fremont, California
    These came back from anodizing early!
    The Introductory Special is now live here: http://www.audizine.com/forum/showth...-Mount-Upgrade!
