So Here's the story including all pertinent details. 2004 1.8t quattro, 6 spd.
I upgraded from Unitronic stage 1+ to stage 2. During this time, i had been throwing a CEL for my rear O2 which decided to sh!t the bed. I ignored it, because this winter has sucked and figured I'd take care of it once spring came. I upgraded to Stage 2, was loving the extra little bump in power, and then i got the bright idea to hook the car up to vagcom and just make sure that i wasn't throwing any new codes since the tune upgrade. Now keep in mind the car was still running great, full power, full boost, no issues other than my check engine light being on, and my traction control light coming on occasionally for a open circuit at the brake light switch. (That also sh!t the bed and i'm replacing that as soon as it arrives) I just wanted to take a look in vagcom and make sure. Here is that log.
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 AK HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0006
Coding: 0016711
Shop #: WSC 78901 281 394790
VCID: 79F3FC87334026E929E-513C
4 Faults Found:
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
16523 - Oxygen (Lambda) Sensor B1 S2
P0139 - 004 - Response too Slow - Intermittent
16524 - Oxygen (Lambda) Sensor B1 S2
P0140 - 004 - No Activity - Intermittent
17522 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 008 - Internal Resistance too High - MIL ON
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04275
Shop #: WSC 06435
VCID: 2649E7FBC27E791134C-5120
1 Fault Found:
00526 - Brake Light Switch (F)
36-10 - Open Circuit - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63251
VCID: 63CFBEEFF1CCCC39132-5120
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 63251
VCID: 356B30B70FD802898D6-4B00
1 Fault Found:
02104 - Light Detection Sensor (G399)
29-10 - Short to Ground - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 2000
Coding: 0010607
Shop #: WSC 63251 000 00000
VCID: 37773ABF45D4F0999FA-513C
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenks·ulenmodul 0308
Coding: 00042
Shop #: WSC 63251
VCID: 3E792F9B3AEEC1D15CC-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 03200
Shop #: WSC 00001
VCID: 32610BABFEB615B1A84-513C
WAUVC68E44A019101 AUZ6Z0C0132270
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortger·t T7B 1311
Coding: 11852
Shop #: WSC 63251
VCID: 72E1CBAB3E3655B1684-4B00
Subsystem 1 - Part No: 8E1959801
Component: Tırsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E1959802E
Component: Tırsteuer.BF BRM 0003
Subsystem 3 - Part No: 8E0959801A
Component: Tırsteuer.HL BRM 0003
Subsystem 4 - Part No: 8E0959802A
Component: Tırsteuer.HR BRM 0003
2 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01561 - Rear left door
59-00 - Can't Unlock
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II NP2 0260
Coding: 01001
Shop #: WSC 01024
VCID: 2C5D15D3DC924341E28-5072
2 Faults Found:
65535 - Internal Control Module Memory Error
08-10 - Control Limit Surpassed - Intermittent
End-------------------------(Elapsed Time: 05:45)--------------------------
After saving the log, I then cleared all DTC's and at that instant is when my car has since been restricted to 15psi. Is it possible my upgrade to stage 2 got wiped and the ECU reverted itself back to stage 1, or am I in limp mode? Anyone have any thoughts whatsoever? I'm baffled at this point.
Now, since there were a few codes in that scan that I had never seen before, after driving the car all weekend and all over the state, I decided to scan the car again, this time I only got the rear O2 code and the brake light switch code. I'm not sure where the alarm tilt sensor, ECM no communication, light detection sensor, and power supply terminal 30 codes came from. I'm thinking when the shop had it maybe they just ran the battery down at some point. However, none of those codes have showed up again.
Now tonight, I changed that rear O2 sensor hoping thats what was causing it and that would restore the power I am currently lacking. It did not. I haven't drove it enough for readiness to set yet, but i'm thinking thats irrelevant. Anyone have anything? I'm stumped.
