Results 1 to 3 of 3
Thread: 06A block
    Jan 25 2013
    Battle Ground, WA
    06A block
    im in desperate need of a 06a block, cars a 04 a4 engine AWM, but I'm pretty sure any 06a block will work. bare or not! thank you!
    gabriel
    3609369123?
    Forum Moderator Four Rings Gumby's Avatar
    Sep 06 2008
    Bellingham, WA
    If you have an 04' it should be an AMB engine code, which is a 06b block. An AWM, which an 06a block would have come out of an 01' only. The thermostat area is different, and won't work with a b6 thermostat. They're close, but not exactly the same.
    -Matt-
    B5 S4, B5 A4 Moderator
    2871r'd 2001 A4 1.8t Build thread
    You may think I'm not online. But I'm always here. Even if I'm not posting. I'm always here. Scrolling. Judging.
    Jan 25 2013
    Battle Ground, WA
    it has an AWM (head on it) the block is an 06a. I'm pretty well aware of the thermostats between the O58 and the 06A, i also have a b5 that i built with the 058 block (AEB)
    but The AWM in mine was manufactured 02-05. And there is a early model of the AWM and a late model, CTS turbo sells a lower ring set for an early and late. mine has the late model.
    Source
    http://www.passatworld.com/forums/no...wers-here.html
    Thank you for the reply tho.
