Results 1 to 16 of 16
    Feb 09 2011
    Iowa
    Suspension cross-reference with Porche
    So, with 170k miles, its time for shocks (ya think?)
    I've noticed that they're basically impossible to come by unless they're $400.. each.
    I've also noticed that they Cayenne shocks appear, physically to be identical. Anyone have any experience with a cross reference of parts?
    Can I use the more available, less expensive Porsche component on the Q?
    2008 Q7 3.6
    No air suspension.
    thanks
    Veteran Member Three Rings sickspeed's Avatar
    Sep 12 2005
    2001 S8 and 2011 Q7 TDI and 2010 Toyota Land Cruiser
    MD
    the Q7 is longer and heavier than the cayenne so many people will claim they are not interchangeable. that being said, i have an aftermarket coilover kit for a cayenne on my Q7 with no problems. if youre considering buying suspension parts anyway, you might consider upgrading to coilovers as well.
    2001 S8 or 2011 Q7 TDI Modded.
    Previous Audis: Red 1987 4000 CS, Dolphin 2002 A4 3.0 6MT Sedan, Atlas 2003 A4 3.0 6MT Wagon, Dolphin 2006 A4 2.0T 6MT Wagon, Meteor 2009 A4 2.0T Wagon S-Line .[/I]
    Feb 09 2011
    Iowa
    What year of Cayenne did you use, what year of Q7 do you have?
    I have no interest in upgrading, I'm very happy with the current setup. I do not have the air suspension. This isn't a racer for me, just a work car.
    Established Member Two Rings Dtomasi's Avatar
    Jan 04 2015
    06 BMW E60 M5 (My Fix)
    NoVA
    Quote Originally Posted by Stoliguy View Post
    Shocks and struts from a 2010 Cayenne or VW Touareg will bolt right in. Tirerack has good prices on shocks and struts.
    Sep 12 2005
    MD
    they bolt right in but the load/spring rates are likely different.
    Feb 09 2011
    Iowa
    If I'm not changing the springs, the shock absorber itself shouldn't matter, right?
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    Correct.
    Daniel J
    @gtg_drives
    Feb 09 2011
    Iowa
    Quote Originally Posted by 87supraman View Post
    Correct.
    Great!
    Anyone have a favorite place to get the best deal on these?
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    Just looking at the Bilstein's, the part # they have for the Touareg and Cayenne is the same, however the Q7 is different. The Q7 application shows all Q7's (V6, V8, TDI) without air suspension. The Touareg ones may bolt up but something must be slightly different about them.
    Daniel J
    @gtg_drives
    Sep 12 2005
    MD
    Again, the Q7 is longer and heavier than the Toureg and Cayenne. You're not going to find part numbers that apply to all 3 models.
    Feb 09 2011
    Iowa
    Quote Originally Posted by sickspeed View Post
    Again, if I'm not changing springs... shocks aren't made differently for weight.. I understand that springs are.
    And, for anyone who needs this... Rock Auto... I was able to get all four shock absorbers shipped for about $500.
    They're listed as a French part, but the part numbers cross reference flawlessly to US version.
    I'll post pics and Part #'s once complete.
    In, Out and Around...
    not sure if this helps in any way but a long time ago one of my previous q7 i swapped out sway bars and other bits. it turns out a great deal of parts from the v12 q7 and touareg and cayenne are shared despite different engine configurations, weights and options. in the link below you may find some part numbers that may help you out in upgrading certain bits and pieces:
    http://forums.quattroworld.com/q7/msgs/3219.phtml
    Feb 09 2011
    Iowa
    Quote Originally Posted by iconoclast View Post
    NICE!
    thanks!
    no problem. good luck. this area of the Q7 is very frustrating because of some many different options in the parts catalog and then it gets even hairier when going back and forth between the vw and porsche parts bins.
    sunset porsche was the most helpful and informative and coincidentally the most competitively priced for the parts. perhaps reach out to them for some assistance.
    Feb 09 2011
    Iowa
    Sounds like you have some experience with this car..
    Any suggestions on what to check, now that I have the suspension replaced, to get rid of the horrid squeaking noise coming out of the front drivers side?
    Bushings? anything typical on this car?
    i ever had that issue but i would guess control arm if it is worn.
    my experience is in lowering and sway bars.
