Results 1 to 9 of 9
    Jan 28 2008
    Germany
    Cannot holds revs
    Guys,
    My 2003 B6 is having problems getting through the UK fast idle smog test. The car is revved up to 2500 has to be held at this rpm for 30s. The problem is that the revs keep on climbing beyond 2500 and if you try and modulate the throttle all revs drop off.
    The car has deleted pre-cats and 100 cell sports cats. It also throws the following codes on a regular basis:
    17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
    P1114 - 008 - Implausible Signal
    16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
    P0140 - 004 - No Signal/Communication
    The sensors themselves were replaced due to the same set of codes but did not make any difference. In summary does anyone have any ideas how ot maintain revs or is the problem related to the codes.
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    Possible maf trouble or maybe a clogged cat. Thats the eldest of b6's!
    Something throwing of the ecu logorythim. Ive heard a bad pcv can have an affect as well. Check all air hoses verify seating and that there are no leaks. If no help then I'd go through all the air sensor connections and reseat.
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
    Veteran Member Three Rings MidwestB6's Avatar
    Aug 01 2013
    1970 Ford Maverick
    Iowa City
    Are you tuned?
    2004 Light Silver 6MT S4
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    with my car (stock tune) , I just cannot hold a certain rpm, the accelerator pedal becomes to sensitive. a bit less throttle= comes back to idle a bit more throttle= rev a bit too high
    Veteran Member Four Rings blai76's Avatar
    Aug 25 2011
    planes, trains and automobiles.
    San Francisco, CA
    Quote Originally Posted by jakeoboy67 View Post
    Piggies, JHM 91, milltek catback, tiptronic here. No problems holding RPM at any RPM.
    Bob
    2008 B7S4tip Avant, 1998.5 B5A4tip 2.8L V6 (retired)
    Jan 28 2008
    Germany
    Quote Originally Posted by SprintBlueWorld View Post
    Thanks guys for the responses. The car is tuned, MAF is within tolerance and the PCV was changed a few weeks back. I'll check the hoses for leaks. I'm inclined ot think that the cat(s) has given up the ghost but would like to rule out any obvious causes.
    Veteran Member Three Rings madkimchi's Avatar
    Sep 09 2009
    Bicycle and roller blade.
    Kent, WA
    Quote Originally Posted by ess_four View Post
    It could be your tune. What kind do you have? Just on this board many people with certain tune have same issue. Cannot hold that 2500rpm. I Think it's all unitronic tune that's causing it but I m not 100% sure.
    Jan 28 2008
    Germany
    Quote Originally Posted by madkimchi View Post
    UPDATE: Tried holding 2500rpm again and all was well for a few seconds until they started to rise slightly and then all revs dropped off. It was like a trip switch being triggered. Checking for leaks later as well as disconnecting the MAF
    Jan 28 2008
    Germany
    It looks like the MAF is the root cause. Reset the TB and still could not hold any revs. Disconnected the MAF and was able to hold revs.
