If you could have an application used to help manage your car, what features would you want? Comment below with a description and a little explanation behind the idea.
To help explain what I mean, I am setting out to create an "all in one" utility for our "other halves". Currently my vision only includes a logging feature to display boost pressure readings graphically in real time, and also give you high, low, and average readings after a run. I am planning on adding a maintnance section where data can be stored and added such as oil changes, mileage it was done at. Basically a way to record your vehicles service record. Possibly even the integration of receipt storage and everything, all easily accessible by party type and/or date searching.
The possibilites are sort of limitless, time is no object to me. No matter how much I have to bury in this project, it's worth it. Its all fun and a great experience for me, but I cant think of all the ideas on my own! Hit me up with ideas, or at least feedback and what I've talked about above, help me make this awesome utility to share!
Ultimately I want to give back to anyone that contributes and the application will be available for anyone to use, and once I get the hardware part tested for reading boost pressures or whatever else we add, Ill create an affordable kit for people to purchase.
The current thread for tracking the progress of the application can be found here.
Thanks for your time fellow Ziners
