I am selling my S4- Long time project in the making... trying to preserve my marriage.
The Car:
2000 S4
140k
Engine:
Frankenturbos - 3000 miles on them
Stage 3 Clutch- 10,000 miles
Coilpack Conversion & ICM Delete Kit from 034
Vast Meth Injection
J-Fonz Custom Tune
Bosch 52lb Injectors
Hitachi MAF, and Large Cone Intake
Manual in cab boost controller (not currently used, but is installed)
3" Down Pipes
3.5" Cat-Back
Test-Pipes (Car will not pass emissions testing!)
Deauchwerks In-Tank high flow fuel pump
JHM B5 S4 "Trio" Package - Short Shifter and Linkage
RS4 Motor Mounts & Transmission Mounts
Suspension:
Koni Coilovers
034Motorsport Solid Rear Sway Bar, Adjustable
Complete set front control arms installed 5,000 miles ago
New wheel Bearings (All 4 wheels)
Now for the bad (hence the fire-sale price)
1. I have relocated to the Nazi state of California, and even if i had catalytic converters in this car the emissions inspector would fail the car for the following: Aftermarket intake, methanol injection system, aftermarket turbos, aftermarket downpipes, and even the fucking silicone inlet hose couplers.
2. Both the driver's window and the passengers window need to have new tracks installed- the parts aren't expensive (40$) and i will even include the parts for the drivers side of the car with the sale...
3. The big kicker- I have been told the synchro collar between gears 1-2 inside the is destroyed.
If you aren't familiar with this problem do some research; there are plenty of replacement kits, or re-built transmissions with the updated synchros that wont fail on the internet.
4. Because the car has been sitting the battery also likely needs to be replaced.
The car has Blizzak snow tires on it presently with 60% tread left.
Any Questions please e-mail me- [email protected]
I will ship the car at the buyers expense through a carrier they organize.
List Date: 3/4/2015
For more info, click here to view the original listing: FS 2000 S4 6MT 140k, STG 3- Frankenturbo
This item is no longer available.
