Results 1 to 10 of 10
    Jan 15 2010
    Santa Barbara, CA
    Diff "lurches" getting into steep driveways sideways - is this normal?
    When driving into steep driveways sideways (so as not to scrape the front), if I end up with only the front passenger-side wheel and rear driver-side wheel touching the ground, the car as a lot of difficulty moving forward. As I clutch out, it lurches and feels like the center diff is slipping or binding. I more or less have to push through it until the second rear wheel touches down, then all is well. To avoid this, I usually try to approach such driveways with enough speed so I can glide all the way until the passenger-side rear wheel touches down, and then engage the clutch and proceed.
    Is this normal? I assume the differentials are attempting to direct power to the non-spinning wheels and is struggling to do so.
    Veteran Member Four Rings badbluers4's Avatar
    Oct 27 2011
    Atlanta, GA
    Yup all of our cars do that. It took me a min to get used to it.
    Jan 15 2010
    Santa Barbara, CA
    Quote Originally Posted by badbluers4 View Post
    Ok thanks, definitely struck me as odd, since none of my previous Audis have done this.
    Mar 11 2008
    B7RS4 & e46Ms
    Sure you're not actually lifting a wheel? I typically 3-wheel on most steep curbs...
    FRRG AZ Ring
    Jan 15 2010
    Santa Barbara, CA
    Oh I'm most definitely lifting at least one wheel, which is exactly why I'm feeling this. But, it seems like the car would handle the power transfer more gracefully - it feels almost like an old 4x4 where the front u-joints would mind and you just had to power through it.
    Veteran Member Four Rings LJH's Avatar
    Oct 03 2006
    '84 Ur-q, '04 S4 6MT, '08 Outback XT 5MT
    Totally normal. All of my Torsen equipped Quattro's have done this, my B6 S4 with H-Sport RS4 bars does it A LOT.
    Cheers,
    Jim
    Veteran Member Four Rings singleframe's Avatar
    Apr 24 2010
    2007 Phantom Black RS4, VW eGolf
    Venice Beach baby!!! 🌞
    Quote Originally Posted by forbiddenbeat View Post
    freaks my wife out a bit sometimes.
    IG @myRS4 | 2007 RS4 | Phantom Black | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | K&N Filtered | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded | window trim matte black vinyl wrapped
    Jan 15 2010
    Santa Barbara, CA
    Quote Originally Posted by singleframe View Post
    Heh, yep, my wife said "your car feels like it's broken". :D
    Oct 11 2007
    Suburbia
    The joys of torsen!
    12' R8 Daytona/CF V10 6MT
    07' RS4 Daytona/Panda
    Mar 11 2008
    B7RS4 & e46Ms
    Okay, just to be clear, half the people in this thread are referring to the drivetrain binding that occurs in the rear when making very low-speed turns. This is due to the torsen center diff, you are correct. What the OP is referring to is what happens to quattro when you completely remove traction from one wheel (i.e. a wheel in the air), basically the car sends all the power to the spinning wheel...when the vehicle regains traction (as in when the spinning wheel finally touches the pavement again), the car will lurch forward due to the mis-match in wheel speeds and current torque load on the drivetrain.
    FRRG AZ Ring
