Results 1 to 17 of 17
    Veteran Member Four Rings Moose201's Avatar
    Aug 26 2012
    2013 S4 Ibis 6MT
    Audi is buying me a new steering rack....how complicated is the install?
    After 2 software updates and an alignment check, my steering still exhibits the occasional center notch. Audi has agreed to install a new rack next week and I'm just curious if this is a fairly straightforward job or if they have to unbolt a lot of other parts (suspension, subframe. etc.).
    www.coldwartourist.com - Exploring ruins & relics of The Cold War
    Prior: 2006 S2000, 2005 S4, 2004 Mazdaspeed Miata, 1999 M3
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    not sure what the job would require but do post the repair job copy to let others know on here what they did.
    Veteran Member Four Rings audibmi's Avatar
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    I had my steering rack replaced with 8K1-423-055-AC steering module along with 18 various nuts and bolts, but the work order does not indicate actual hours since it was covered under warranty.
    I would request a 4 wheel alignment and a pre-inspection of your steering wheel in case they scratch the leather by accident upon removal/reinstall.
    Veteran Member Three Rings tanklee's Avatar
    Dec 31 2004
    NJ / Miami
    install is pretty easy and straigt forward. remove subframe brace, disconnect steering shaft to steering rack, disconnect the connectors to steering rack, undo tie rod ends, and unbolt steering rack. then you have to code and adapt a bunch of stuff afterwards like the steering angle sensor, steering module, component protection, etc.
    2000 B5 A4 Quattro
    2000 B5 S4 6spd Stage 3
    2014 B8.5 S4 DSG
    2005 B6 A4 Quattro USP
    Established Member Two Rings WeeKenny's Avatar
    Jan 05 2015
    Scotland
    Audi quote 9 hrs to do it
    Aug 26 2012
    2013 S4 Ibis 6MT
    Quote Originally Posted by tanklee View Post
    I guess I can assume that they will replace any stretch bolts with new ones?
    Senior Member Three Rings Ryan_qttro's Avatar
    Oct 17 2011
    2005 2.7T Allroad
    Baton Rouge, Louisiana
    Quote Originally Posted by Moose201 View Post
    They may, if you want Alu Kruez now is the time.
    05 2.7T Allroad
    Audi Tech
    Apr 04 2012
    MSP
    Quote Originally Posted by Ryan_qttro View Post
    And now's time to do sway and links too...
    Aug 26 2012
    2013 S4 Ibis 6MT
    Quote Originally Posted by audibmi View Post
    Good suggestion, thanks.
    Oct 14 2012
    Empty...for now...
    SE PA
    Are you lowered or on stock suspension?
    SOLD 2015 Daytona Gray S4
    Aug 26 2012
    2013 S4 Ibis 6MT
    Quote Originally Posted by SteveYem View Post
    Stock suspension.
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    What symptoms do you have? Sometimes on a cold start it seems like there are "notches" in the steering where its hard to go inbetween the two set positions
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Aug 26 2012
    2013 S4 Ibis 6MT
    Quote Originally Posted by B8 S4 View Post
    The center notch steering problem has been well documented in these forums and mine seems to be a milder version of what others have experienced. When they did the 48k8 software update about a year ago, the problem seemed to be gone once and for all but it crept back as the temperatures dropped late last year. There is a seemingly random pattern as to when it decides to appear which means that the likelihood of it being experienced by an Audi Tech during a test drive is slim. I thought it would really flare up with recent cold temperatures but it didn't. The randomness of it all makes it slightly maddening.
    Oct 02 2013
    Ottawa
    How did you convince them that the problem actually exists? My local dealer won't touch anything unless their tech can observe it first hand.
    Aug 26 2012
    2013 S4 Ibis 6MT
    Quote Originally Posted by dowzer View Post
    I wrote a detailed letter to Audi of America outlining the problem along with the steps my dealer took to remedy the situation followed by the recurrence of the problem. I received a prompt and polite phone call from AoA that lead to the new steering rack being offered as their solution.
    Aug 26 2012
    2013 S4 Ibis 6MT
    They are doing the install today and using the following parts:
    Steering rack - 8K1423055BR
    Intermediate steering shaft - 8K1419753G
    Should have the car back tomorrow.
    Aug 26 2012
    2013 S4 Ibis 6MT
    Okay, it's done. New steering rack, new steering shaft, 4 wheel alignment. Test driven by the tech as well as the TSM. The drive home was okay but the coming weeks and months will be the real test. Fingers crossed.
