Results 1 to 6 of 6
    Nov 13 2014
    Fort Collins/Colorado
    Can you lose boost after installing a FMIC
    I know I went dark after posting an intro, but I have been really busy between snowboarding and work. The car though, I have been running at 10psi on an APR 93 tune, I was told by the previous owner the boost went down after installing the fmic, but I'm not so convinced, Don't know the brand, so I'm going to assume eBay. I'm trying to make it run as it should before I sell it later this month. Does anyone have input, could it be the intercooler, piping, or just boost loss due to travel and volume of the intercooler?
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    You shouldn't be losing ~8psi from a FMIC. Do a boost leak test.
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Veteran Member Four Rings pbcrazy's Avatar
    Feb 06 2013
    VA
    Yes: You can have a boost drop after installing a FMIC.
    No: A normal FMIC will not drop 8 psi if everything is fine. About 1psi drop at 20psi is normal.
    98.5 Audi A4 1.8T Quattro | 5 Speed | AEB | Laser Red
    | FrankenTurbo F21L | United Motorsports Stage 3 | 630cc Injectors | 3" MAF | ICM Delete w/FSI Coils | Scorpion 2.5" Catback/RAI 3" Test Pipe | Forge 007 | 034 Silicone PCV | Alzor 349 | FMIC | ECS RA4 LWFW/S4 Clutch/S4 P.Plate | AEM | Krauto | etc.
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    Check for following.
    1.pcv check
    2.n75 valve check
    3.pcv to intake manifold check
    4. Hose connections from turbo to fmic and other side
    5.clean maf or check maf
    6. Check Dv
    7. As mentioned above do a leak test.
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Yes, but not that much. Check/do ^^^
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Sounds like the car might be in limp mode. What year is the car? 10psi tends to be boost pressure while in limp mode on a aftermarket K03 tune.
